Many typing mistakes :(
Line 8 the word engine i meant to say engine power.
Line 9 the word without i meant with.
رقم العضوية : 79524
الاقامة : Cairo, Egypt
السيارة: 2009VW Passat 1.4TSI
السيارة[2]: 2007Skoda Superb 1.8T
ABS = Prevents wheels from locking when braking the car hard
ESP = Is a complete program that keeps sensing the 4 wheels of the car in relation to the steering wheel. If it detects anything wrong then it starts working. It works by braking 1 or more wheels of the car.
ASR = Prevents wheels from spinning for any reason, whether its hard acceleration or due to driving on slippery ground.
If a car has ESP then it should have ABS but the opposite is not true. A car may have only ABS without the others.
So ESP uses ABS & ASR to stabilize the car.
Last thing, many people think that ASR makes the car acceleration worse. This is not true. It is the opposite. If the wheels go spinning then it means that some engine is wasted because its not transferred from the wheels to the ground in order to accelerate the car. The tires spin fast without a lot of noise making the driver think he is getting good acceleration but the opposite is happening. It is just noise.
This is why ASR stops the spinning once it happens by decreasing power & once the spinning stop the power is increased again & so on, so that in the end all the engine power is transferred into real speed on the road.
In short, ASR does not make the car slower. It helps it accelerate better. A very good driver can do without ASR by doing the job of ASR manually by himself. If he detects the wheels will spin he can release the gas pedal slightly, then press on it again & so on. He must be very sensitive but in general the computer doing this job will be more efficient.
Sorry for english. I hope I do not upset anybody :)
رقم العضوية : 79524
رقم العضوية : 17999
الاقامة : El-Haram, Giza
السيارة: Mercedes C200 K 09
السيارة[2]: Kia Cerato High Line 09
hassansh
كلام مظبوط, و متفق معاك في كل كلامك, و هو ده بالظبط اللي انا قلته يا باشا...
لكن هختلف معاك في موضوع السيارات الدفع الخلفي, لانها بالفعل
اكثر ثبات من الجر الامامي و ده للسبب اللي انا شرحته قبل كده,
لكن سواء جر امامي او دفع خلفي الاثنين ممكن يحصل و تفقد السيطره
على العربيه, او تفقد اتزانها لاي سبب من الاسباب, لكن لو حطينا افتراض
ان ده هيحصل مثلا في الجر الامامي 30%, يبقى في الدفع الخلفي 15% بس
لكن ده مش قانون, و مافيش قانون للكلام ده, لكن لكل نظام مميزات و عيوب
و النسبه دي هي اللي هتفرق في احساس اللي راكب بي ام مثلا, و اللي راكب جيتا
او اي عربيه جر امامي في مقابل اخرى دفع خلفي...
دي وجهة نظري يا باشا, و عموماً رأيك يحترم تماماً...
تقبل تحياتي...
Eng. Mohammed Ghazy
The New Mercedes-Benz C 300
رقم العضوية : 79524
ghazy12
I will write in english easier than arabiic with english letters
I also agree with you but about the RWD & FWD i really am not sure
If the RWD is generally better then why did BMW change their 3-series from RWD to be FWD. And BMW is not a cheap car at all & are known for their good stability. Anyways, as I said i am not expert so maybe you are right, especially that many expensive cars are RWD not FWD but those higher than the 3series
رقم العضوية : 16528
الاقامة : maadi
السيارة: dodge spirit
السيارة[2]: elantra 2008 jetta 2009
دراجة بخارية: -
رقم العضوية : 79524
I made a mistake. I thought they already changed. They only have plans for it
BMW confirms plans for front-wheel-drive models — Autoblog
If there's one thing that's certain in this crazy world, it's that Ultimate Driving Machines are driven by their rear wheels. Sure, there's an occasional all-wheel-drive model thrown in for good measure, but even those revert to the tried-and-true RWD when extra traction from the front two contact patches isn't deemed necessary or desirable. Well, ..... the media (oh, wait...): BMW has confirmed the rumors that it will build front-wheel-drive automobiles.
رقم العضوية : 79524
رقم العضوية : 27398
الاقامة : Egypt
السيارة: Sunny 2011
السيارة[2]: X - A 516
معلش انا عاوز اقول على تجربة الثبات و الشد بتاع الجيتا و ال 318 و عربيتى
كنت يوم طالع على الشغل الساعة 7 صباحا كان فى شويه شباب معاهم جيتا و شاب سايق 318 عملين يكسروا على بعض و بيشد مع بعض و الكلام ده كان فى امتداد شارع التسعينى من ناحية القرافات اللى فى مدينه نصر المهم اللى سخنى ان هما كسروا عليا بغشم
فقلت و الله لوريهم رحت جايب التالت ة كابس بنزين للاخر لحد ال ار بى ام ما جاه على ال 6 و جبت الرابع و كبس بنزين لحد برده الر بى ام 6 و رحت يا عم من جانب الجيتا و رحت طاير كانت السرعة 150 كيلو و رحت بصيت للعيال بتوع الجيتا طبعا هما كبسين و مش محصلينى قلت بس هما كده كفايه اتربوا اخر تربية
و قلت اروح لبتاع ال 318 نربيه برده الصراحة و الحق يقال انا عمال كابس لحد ال 160 و مش عارف احصله تماما لحد ام وصلنا عند الصنيه اللى بتدخلك على اول شارع التسعينى
طبعا بتوع الجيتا خلاص اتربوا
كنت انا و بتاع ال 318 عمال احاول اجيبه مش عارف
لحد اما وصلنا عند الصنيه اللى عند تقريبا الفندق ( مش فاكر اسمه صراحة ) و الطريق واسع وفاتح و مفيش بتوع النص نقل اللى سدين الطريق طبعا انا قرص على الماتور على الاخر قمت طاير من جنبه طير بس قعدت لحد ال 150
شويه ولقيت ابن الايه راح هههههههههههههههوووووووووو ووووووووووففففففففففففففف فف من جنبى و اختفى من امامى
طبعا مقدرتش احصله تمام و قعد كابس لحد 180 فقلت خلاص كفايه كده ان الماتور حيطلع من العربية
قلت لنفسى كفايه كده ان انا بهدلت بتاع الجيتا و صمدت و عديت ال 318
بس هو فى الاخر اختفى من امامى
رقم العضوية : 31428
الاقامة : zagazig
السيارة: seat 133
السيارة[2]: vw polo 99
رقم العضوية : 61933
الاقامة : الهرم, الجيزة
السيارة: LADA 2105 1994
السيارة[2]: SEAT IBIZA AT 2010
