اولا ازيك يا محمد عامل ايه ؟
خدنا الاجازه يا عم و محدش قدنا :))
ثانيا بقى دى طريقه عمل القفله و مكان الفيشه بالظبط و كمان اكواد لمبه ال check engine كامله "
To locate the codes that are stored in the ECM you will need to locate the plug on the passenger side, under the kick panel. Where the passengers right foot would be, down below the glove compartment on the side in front of the door. There will be a plastic kick panel, it matches the interior of the car, just pry that off, as it is only held on by clips. It is a two wire connector, you need to place a jumper wire from one side to the next (a paper clip will work nicely), turn the key to "run" or "on" not start it...then count flashes of the engine light on the dash as mentioned above. Codes remain the same. A long flash equals 10. A short flash equals 1. So if you get 4 long flashes that would equal 40.Three short flashes would equal 3. Four long flashes + three short flashes = code 43. you may have multiple codes stored in the ECM and will repeat themselves over and over, the will be a pause in between codes. Here is a listing of the codes:Code 0 and 11 Electronic Control Module (ECM)Code1 Heated oxygen sensor A
Code 2 Oxygen ....... B
Code 3 and 5 Manifold Absolute Pressure
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECM
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
Code 30 A/T FI signal A
Code 30 A/T FI signal B
Code 41 Heated oxygen sensor heater
Code 43 Fuel supply system
Code 45 Fuel supply metering
Code 48 Heated oxygen sensor
Code 61 Front heated oxygen sensor
Code 63 Rear heated oxygen sensor
Code 65 Rear heated oxygen sensor heater
Code 67 Catalytic converter system
Code 70 Automatic transaxle
Code 71 Misfire detected cylinder 1
Code 72 Misfire detected cylinder 2
Code 73 Misfire detected cylinder 3
Code 74 Misfire detected cylinder 4
Code 75 Misfire detected cylinder 5
Code 76 Misfire detected cylinder 6
Code 80 Exhaust recirculation system
Code 86 Coolant temperature
Code 92 Evaporative emission control system"
