صفحة 7 من 8 الأولىالأولى ... 2 3 4 5 6 7 8 الأخيرةالأخيرة
النتائج 61 إلى 70 من 79
  1. #61
    الصورة الرمزية farahat
    رقم العضوية : 2264
    السيارة: N/A
    السيارة[2]: BMW
    دراجة بخارية: NA
    الحالة : farahat غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة Ahmed Hassan مشاهدة المشاركة
    طيب ايه المشكله؟؟ ليه مينفعش يكون فيه سينسور؟!! هوه الكنترول ميعرفش سرعه العربيه؟!! برجاء قراءة المقطع التالي من ويكيبيديا
    Most power steering systems work by using a hydraulic system to rotate the vehicle's wheels. The hydraulic pressure is usually provided by a gerotor or rotary vane pump driven by the vehicle's engine. A double-acting hydraulic cylinder applies a force to the steering mechanism, which in turn applies a torque to the wheels. The flow to the cylinder is controlled by valves operated by the steering wheel. There are several common valve systems of varying complexity, but they all allow the steering wheel to turn further than is necessary to simply open a valve. This is done so that the position of the steering wheel corresponds to the position of the vehicle's wheels. As the pumps employed are of the positive displacement type, the flow rate they deliver is directly proportional to the speed of the engine. This means that at high engine speeds the steering would naturally operate faster than at low engine speeds. Because this would be undesirable, a restricting orifice and flow control valve are used to direct some of the pump's output back to the hydraulic reservoir at high engine speeds. A pressure relief valve is also used to prevent a dangerous build-up of pressure when the hydraulic cylinder's piston reaches the end of the cylinder.
    Some modern implementations also include an electronic pressure relief valve which can reduce the hydraulic pressure in the power steering lines as the vehicle's speed increases (this is known as variable assist power steering).
    شكراً على الإضافة المفيدة دي ، شكراً جزيلاً
  2. #62
    الصورة الرمزية lanos2
    رقم العضوية : 9343
    الحالة : lanos2 غير متواجد حالياً
    كل اللى حضرتك قولته على عينى و راسى بس فعلا ليس عندى فى الباور الهيدروليك اى اتصال بأى كنترول او شى يعرفة مقدار سرعة السيارة و لا عجلة القيادة بتتقل على السرعة العالية كما تقولون تحب احلفلك .
  3. #63
    رقم العضوية : 2264
    السيارة: N/A
    السيارة[2]: BMW
    دراجة بخارية: NA
    اقتباس المشاركة الأصلية كتبت بواسطة lanos2 مشاهدة المشاركة
    ماهو ذي ما مكتوب حضرتك "some modern implementations ..." ، يعني مش كل الموديلات فيها ، بعض الموديلات الحديثة فقط ، و أكيد مش هتكون في السيارات العادية أكيد هتكون في فئة السيارات العالية .
  4. #64
    رقم العضوية : 9343
    فى الباور الكهربائى نرى ان موتور تحريك عجلة القيادة متصل بأكس حلزونى يسمى دودة داخل علبة تروس صغيرة و يحرك ترس متصل بمحور عجلة القيادة و هذا يعنى ان الموتور هو الوحيد الذى يسطيع تحريك عجلة القيادة و عجلة القيادة لا تستطيع تحريك الموتور اذا تعطل بناء على هذا التصميم الموجود امامنا .
    اذا قد يكون المقصود ان الموتور يبطىء استجابته و سرعته على السرعة العالية للسيارة فى الباور الكهربائى ثم يعود الى قوته مع انخفاض سرعة السيارة .
    و لكن ماذا يحدث اذا تعطل هذا الموتور نتيجة فيوز او تهنيج فى الكنترول ففى هذه الحالة لا مجال لتحريك عجلة القيادة و هذا ما يؤدى الى الحوادث على ما اعتقد لان التصميم الميكانيكى لصندوق التروس الخاص بالموتور الكهربائى كما هو واضح بالصور يسمح فقط للموتور بتحريك عجلة القيادة و ليس العكس حد فاهم حاجة ؟؟؟؟؟؟
  5. #65
    الصورة الرمزية Ahmed Hassan
    رقم العضوية : 388
    الاقامة : Port Said
    السيارة: N/A
    السيارة[2]: BMW 330i
    دراجة بخارية: N/A
    الحالة : Ahmed Hassan غير متواجد حالياً
    الدريكسيون في حاله الباور الكهربائي اسهل جدا في تحريكه لو العربيه مطفيه من الباور الهايدروليك. يعني لو عملت unlock للدريكسيون عن طريق انك تلف المفتاح لفه واحده من غير ما تفتح كونتاكت او تدور هتلاقي انك ممكن تلف الدريكسيون و هتحس بمقاومه الموتور الكهربي.. و لكنها مقاومه خفيفه مقارنه بالباور الهايدروليك في حاله مماثله.
    Thanks
    Ahmed Hassan
    When all you have is a hammer, everything looks like a nail
  6. #66
    الصورة الرمزية ramyayash
    رقم العضوية : 10453
    الاقامة : saudi arabia
    السيارة: gallant
    السيارة[2]: yaris
    الحالة : ramyayash غير متواجد حالياً
    انا بالفعل لما اشتريت العربيه دي جبت اخر الدركسيون ما سمعتش زنه الباور
    رحت لميكانيكي تبعي بص قالي الاسكارته بتاعت العربيه مافيش خراطيم موصله ليها
    قلتله يعني ايه
    قالي يعني مش باور
    قلتله ازاي
    قالي زي الناس الفيات تيمبرا كده برضو
    علبه دركسيون ناعمه وسوسته بالكهربا لحتكم السرعات العاليه
    بيني وبينكم اتضايقت
    الباور لفتين يجيب اخر الكاوتش
    النيو اكسنت 4 لفات ونص
    عموما قدر الله وما شاء فعل
  7. #67
    الصورة الرمزية el_saher101
    رقم العضوية : 11195
    الاقامة : egypt
    السيارة: نوبيرا
    السيارة[2]: 128 فيات
    الحالة : el_saher101 غير متواجد حالياً
    افتراضي مشكلة كبيرة -
    ايوة فعلا انا معايا النيو اكسينت والعربية دى مشكلتها كبيرة جدا انها متذودة بمتور قوى جدا وبعجلة قيادة سلسلة جدا ذيادة عن الزوم وفعلا عجلة القيادة مبتفصلش فى السرعات وانا نفسى كنت هعمل حدثة على طريق العبور بسسبب البور مع العلم انى كنت ماشى على 100 كيلو
  8. #68
    الصورة الرمزية smsmbakr
    رقم العضوية : 6790
    الاقامة : ALMENOFIA
    السيارة: VERNA
    السيارة[2]: VERNA 2008
    الحالة : smsmbakr غير متواجد حالياً
    فعلا عيب قاتل وربنا يحفظنا جميعا من شر العيوب ديه
  9. #69
    الصورة الرمزية mmolazem
    رقم العضوية : 8581
    السيارة: Verna
    السيارة[2]: Fiat 128
    الحالة : mmolazem غير متواجد حالياً
    كده يبقى استحاله ان عجلة القياده تتحرك فى حالة تعطل موتور الباور.
    اقتباس المشاركة الأصلية كتبت بواسطة lada kalina مشاهدة المشاركة
    و لكنه يصبح فجاة على اليسار لين جدا جدا جدا لدرجة انه بنفخة يروح للاخير و على اليمين صلب كالصخر او العكس و هنا تكمن الكارثة و هناك العديد و العديد و العديد من الوفيات التي حدثت و بخاصة على السرعة العالية جدا حيث الوفاة اكيدة
    يعنى عند المناوره على الطريق (او الغرز) ممكن يصادف عطل فجائى فى الباور ...؟؟؟ ..... و تحصل كارثه .. ؟؟؟
    اقتباس المشاركة الأصلية كتبت بواسطة el_saher101 مشاهدة المشاركة
    وده له علاقه بنفس الموضوع .... ولا حاجه تانيه ....
    عموما ربنا يستر.
    ما بين ميلاد رسول الله موسى وهلاك فرعون عشرات السنين . . يُمهل ولا يُهمل !!
  10. #70
    الصورة الرمزية Matrixawy
    رقم العضوية : 10720
    الاقامة : CAIRO
    الحالة : Matrixawy غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة mmolazem مشاهدة المشاركة
    عموما ربنا يستر.
    الموضوع واضح انه خطير جدا و يجب تحذير الاعضاء من هذه السيارة
    مع العلم انى سمعت ان هناك مشاكل حدثت بالفعل من هذا الباور الكهربائى فى النيو اكسنت
    و عندما يذهب صاحب السيارة الى غبور لا يقوموا بأصلاحه مرة اخرى بل يقوموا بتغيره كله بباور هيدروليك بدلا منه
    و هذا ان دل فيدل على ان الباور الكهربائى فى هذه السيارة به كارثة لذلك لا يقوموا بتغيره بمثله
    و الغريب فى هذا الامر ان هيونداى او غبور لا يقوموا بسحب هذه السيارات من السوق او تعديلها الا بعد تسببها فى كوارث للناس رغم علمهم بأن هذا عيب قاتل و لا يجب السكوت عليه
  1. قاتل يا مقتول
    بواسطة Eng.Geo في المنتدى المنتــــــدى العـــــــــــام للسيــارات
    مشاركات: 35
    آخر مشاركة: 22-06-2011, 10:12 PM
  2. انا مش اسف يا قاتل الاطفال
    بواسطة tamer_a7 في المنتدى المنتــــــدى الاجتمــاعى
    آخر مشاركة: 15-06-2011, 07:19 PM
  3. البنزين في مصر فيه ..... قاتل
    بواسطة Samir Elshahawy في المنتدى المنتــــــدى العـــــــــــام للسيــارات
    مشاركات: 52
    آخر مشاركة: 11-01-2010, 10:41 PM
  4. لا تشرب ....الزجاجه بها سم قاتل
    بواسطة heronasser في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 12
    آخر مشاركة: 15-02-2008, 05:23 PM
