ManufacturerOPELModelVectraStroke cc1598Kilowatts55Fuel TypePetrolNumber Of Cylinders4Engine TypeSOHC/OHCEngine CodeC16NZFrom09-1988Till11-1995Part No.TypeCommentsFitmentUniversal Part No.
60078ABS SensorFront
60078ABS SensorFitting Position Front Axle
51720Brake light Switch2 Terminals
51723Brake light Switch
18764Crankshaft Sensor
44850Distributor CapKAT Delco
44850Distributor CapDelco
45772Distributor CapBosch/Valeo
14900EGR Valve12/93->
55450Engine Management Temperature SensorBlue top
55523Engine Management Temperature Sensoroil temp. sensor
58900Flasher Unit
58940Flasher UnitFor Trailer
31538Fuel Pump
14800Idle Control Valve
12626Ignition CoilKAT Delco
12626Ignition CoilX16SZ Del system
76332Ignition Lead Set>>Engine No 02N52986SAE
76333Ignition Lead SetChassis No R100001,R5000001,R7500001>>SAE
73866Ignition Lead SetWithout Heat Shields - With Coil
LeadM4
