well the obvious is to put a 1.6 vtec or if you want more power put the 1.8
but if i were you and i got MONEY i will put the 2.2 VTEC
رقم العضوية : 900
السيارة: 2car
السيارة[2]: 1car
رقم العضوية : 3971
الاقامة : Giza-Egypt
السيارة: 4G93T
السيارة[2]: Mitsubishi Lancer GSR CK1A
دراجة بخارية: n/a
So any K20 swaps done here in Egypt?, I know it's a pretty pita job
VTEC: All of the lag...none of the BOOST l
رقم العضوية : 1303
السيارة: Hyunai i10
السيارة[2]: BMW 325i E46
رقم العضوية : 3971
السيارة: 4G93T
دراجة بخارية: n/a
Yeah....and from what I understand this engine (K20) spins clockwise, right? So if you swap it into an old Honda, which had counter clockwise spinning engines, and reversed intake/exhaust plumbing, you end up with the transmission on the left and the motor on the right...
As I said earlier it must not be an easy swap. Can it be done here in Egypt without compromising the structure ?l
رقم العضوية : 1303
السيارة: Hyunai i10
رقم العضوية : 1726
الاقامة : شبراا
السيارة: BMW M40
السيارة[2]: fiat 124 B coupe
دراجة بخارية: ZX12r
Makan el sir kteer fe el shona we feh meno el 160 hp we feh meno el 170 hp tayeb we akeed kolo bydawar 3ala el 170 hp
Tayeb te3rafo menen ?
Bos ya sedy awel ma nezel sir kan fe el Honda model 1988-1991 we dol kolohom 160hp ely homah bysamoh 4th generation ely bysamoh SIR we dah kan controloh OBD 0 ya3nee feshteen bas
We can el ftees bata3oh Kaman sawa2 manual 2w 2utomatic byn2al el 7arka 3an taree2 capl enama fe el model ely ba3d keda 1992-1995 5th generation we dah fe menhom el 160- we fe menoh 170hp kan ftesoh byn2al el 7araka be 7aga esmaha hydro ( hydromatic ) we la7ez en hydromatic de mesh ma3naha automatic
We ba3d keda men model 1996-2000 we dah ely hoah 6th generation we dol bardo fe menhom 160hp-we feh 170 hp we el 5th generation we 6th generation zay ba3d belzabt fe el power we fe 7agat kteer we el far2 benhom bas fe el controlat 7ayth el 5th generation 3 fesha obd1
We el 6th generation 4 fesha obd2 we el 2 bysamohom SIRII
El mokarna ben el sir
SIR 1988-1991
-El ftees beta3oh byeb2a capl,
-El compression ratio, 10.2:1
-7asas el hawah beta3oh byeb2a selkeen bas-
-7asas daght el hawah byeb2a met3ala2 fe el sedr ely wara
-el dfyra lonha creamy-
- el manifold byetkatab 3aleh PGMf1
- Kelmet DOHC kbera we vrec soghayara
-El serial no beta3 el motor dayman byebda2 be 1xxxxxxx
SIRII 1992-2000
-El ftees beta3o menoh hydro
-El compretion ratio beta3to fe menha 10.2:1 fe el 160 hp we 10.4:1 fe el 170 hp
-7asas el hawah beta3oh byeb2a 4 selk
-7asas daght el hawa beyb2a laze2 fe el manifold ely fo2 el makna
-el dfyra lonha ramady
-el manifold maktoob 3aleh MPFI
-kelmet VTEC kbera we dohc
-el serial no beta3 el motor dayman byebda2 be 5xxxxxxx
hat2olee tayeb ma ana ma3reftesh keda el 170hp ha2olak en 2ay sirII yabany yeb2a 170HP we te3raf eno yabany men el code bata3oh byeb2a B16A bas we mafeesh rakam ba3d el A we yekon modeloh ba3d el 1992 we de tekshef 3aleha zay ma fe elsora keda
http://img150.imageshack.us/img150/3616/i036xz6.th.jpg
SOURCE:http://www.tawdeeb.com/forums/index.php?showtopic=1259
FiaT FoR EveR
رقم العضوية : 2802
الاقامة : elrehab city
السيارة: bmw
السيارة[2]: bmw
دراجة بخارية: r
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
رقم العضوية : 1303
السيارة: Hyunai i10
Mosad # 0122856007
Adly # 0122812031
Both are partners and both worked in Honda dealer but Mosad is the crack head type ;)
Horsepower is how fast you hit the wall....torque is how far you take the wall with you
