if you change ball joints of pinion and rack and you dont lock them to the same spot as the ones you replaced, rack travel will change, then you realign your wheels and you will find the travel is the same for both tyres, then you adjust the steering wheel, or at least this is exactly what I did last time and everything is okay here
