رقم العضوية : 131307
السيارة: .
السيارة[2]: E46
الجزء الخامس عشر :
P1477 MFC Primary Circuit Failure (***(May not be applicable for Honda / Acura)***)
P1478 Battery Temp Sensor Volts Out of Limit (***(May not be applicable for Honda / Acura)***)
P1479 Transmission Fan Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1479 HFC Primary Circuit Failure (***(May not be applicable for Honda / Acura)***)
P1480 PCV Solenoid Valve (***(May not be applicable for Honda / Acura)***)
P1480 Cooling Fan Relay 1 Circuit High Input (***(May not be applicable for Honda / Acura)***)
P1482 Catalyst Temperature Sensor Circuit Shorted Low (***(May not be applicable for Honda / Acura)***)
P1483 Engine Cooling System Performance
P1483 Catalyst Temperature Sensor Circuit Shorted High (***(May not be applicable for Honda / Acura)***)
P1484 Catalytic Converter Overheat Detected (***(May not be applicable for Honda / Acura)***)
P1485 Air Injection Solenoid Circuit (***(May not be applicable for Honda / Acura)***)
P1486 Evap Leak Monitor Pinched Hose (***(May not be applicable for Honda / Acura)***)
P1487 Hi Speed Rad Fan CTRL Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1488 Auxiliary 5 Volt Supply Output Too Low (***(May not be applicable for Honda / Acura)***)
P1489 High Speed Fan CTRL Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1490 Low Speed Fan CTRL Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1490 Vacuum Cut Valve Bypass Valve (Circuit) (***(May not be applicable for Honda / Acura)***)
P1491 Malfunction In EGR System
P1491 Rad Fan Control Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1491 Vacuum Cut Valve Bypass Valve (***(May not be applicable for Honda / Acura)***)
P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit) (***(May not be applicable for Honda / Acura)***)
P1492 Ambient/Batt Temp Sen Volts Too High (***(May not be applicable for Honda / Acura)***)
P1493 Ambient/Batt Temp Sen Volts Too Low (***(May not be applicable for Honda / Acura)***)
P1493 EVAP Canister Purge Control Valve/Solenoid Valve (***(May not be applicable for Honda / Acura)***)
P1494 Leak Detection Pump Switch or Mechanical Fault (***(May not be applicable for Honda / Acura)***)
P1495 Leak Detection Pump Solenoid Circuit (***(May not be applicable for Honda / Acura)***)
P1496 5 Volt Supply Output Too Low (***(May not be applicable for Honda / Acura)***)
P1498 Vol***e Problem In EGR Valve Position Sensor Circuit
P1498 High speed Rad Fan Ground CTRL Rly Circuit (***(May not be applicable for Honda / Acura)***)
P1500 Idle Speed Control Valve Stuck Open (***(May not be applicable for Honda / Acura)***)
P1500 Vehicle Speed Sensor (VSS) Intermittant (***(May not be applicable for Honda / Acura)***)
P1500 Generator FR Terminal Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1501 Idle Speed Control Valve Stuck Closed (***(May not be applicable for Honda / Acura)***)
P1501 Vehicle Speed Sensor (VSS) Out Of Range (***(May not be applicable for Honda / Acura)***)
P1502 Idle Speed Control Valve Closing Solenoid Control Circuit Signal High (***(May not be applicable for Honda / Acura)***)
P1502 Vehicle Speed Sensor (VSS) Intermittant (***(May not be applicable for Honda / Acura)***)
P1502 Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1503 Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1504 Idle Speed Control Valve Closing Solenoid Control Open Circuit (***(May not be applicable for Honda / Acura)***)
P1504 Idle Air Control (IAC) Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1505 Idle Speed Control Valve Closing Solenoid Control Circuit Electrial (***(May not be applicable for Honda / Acura)***)
P1505 Idle Air Control At Adaptive Clip (***(May not be applicable for Honda / Acura)***)
P1506 Idle Speed Control Valve Open Solenoid Control Circuit Signal High (***(May not be applicable for Honda / Acura)***)
P1506 Idle Air Control System Overspeed Error (***(May not be applicable for Honda / Acura)***)
P1507 Idle Speed Control Valve Open Solenoid Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1507 Idle Air Control System Underspeed Error (***(May not be applicable for Honda / Acura)***)
P1507 Idle Control System Malfunction (Fail-Safe) (***(May not be applicable for Honda / Acura)***)
P1508 Idle Air Control (IAC) System - Low RPM
P1508 Idle Air Control Valve Circuit Failure
P1508 Idle Speed Control Valve Opening Solenoid Control Open Circuit (***(May not be applicable for Honda / Acura)***)
P1509 Idle Speed Control Valve Opening Solenoid Control Circuit Electrial (***(May not be applicable for Honda / Acura)***)
P1510 Idle Speed Control Valve Stuck (***(May not be applicable for Honda / Acura)***)
P1511 DISA Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1512 DISA Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1513 DISA Control Circuit Signal High (***(May not be applicable for Honda / Acura)***)
P1516 Inlet Manifold Runner Control Input Error (Bank 1) (***(May not be applicable for Honda / Acura)***)
P1517 Inlet Manifold Runner Control Input Error (Bank 2) (***(May not be applicable for Honda / Acura)***)
P1518 Inlet Manifold Runner Control Stuck Open (***(May not be applicable for Honda / Acura)***)
P1518 Starter Switch Circuit Low Input (***(May not be applicable for Honda / Acura)***)
P1519 Malfunction In IAC Valve Circuit
P1519 "A" Camshaft Position Actuator Bank 1 (***(May not be applicable for Honda / Acura)***)
P1519 Inlet Manifold Runner Control Stuck Closed (***(May not be applicable for Honda / Acura)***)
P1520 Intake Manifold Runner Control (IMRC) circuit malfunction
P1520 "B" Camshaft Position Actuator Bank 1 (***(May not be applicable for Honda / Acura)***)
P1520 Stop Light Switch Signal Malfunction (***(May not be applicable for Honda / Acura)***)
P1521 Power Steering Switch Malfunction (***(May not be applicable for Honda / Acura)***)
P1522 "A" Camshaft Position Actuator Bank 2 (***(May not be applicable for Honda / Acura)***)
P1523 "A" Camshaft Position Actuator Signal Low Bank 1 (***(May not be applicable for Honda / Acura)***)
P1524 Throttle Position (TP) Sensor Learned Closed Throttle Angle Degrees Out-Of-Range
P1524 "A" Camshaft Position Actuator Signal High Bank 1 (***(May not be applicable for Honda / Acura)***)
P1525 Throttle Position (TP) Sensor Learned Closed Throttle Angle Degrees Out-Of-Range
P1525 "A" Camshaft Position Actuator Control Open Circuit Bank 1 (***(May not be applicable for Honda / Acura)***)
P1526 "A" Camshaft Position Actuator Control Open Circuit Bank 2 (***(May not be applicable for Honda / Acura)***)
P1527 Trans Range / Pressure Switch Comparison
P1527 "A" Camshaft Position Actuator Control Circuit Signal Low Bank 1 (***(May not be applicable for Honda / Acura)***)
P1528 "A" Camshaft Position Actuator Control Circuit Signal High Bank 1 (***(May not be applicable for Honda / Acura)***)
P1529 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 1 (***(May not be applicable for Honda / Acura)***)
P1530 "B" Camshaft Position Actuator Control Circuit Signal High Bank 1 (***(May not be applicable for Honda / Acura)***)
P1531 "B" Camshaft Position Actuator Control Open Circuit Bank 1 (***(May not be applicable for Honda / Acura)***)
P1532 "B" Camshaft Position Actuator Control Open Circuit Bank 2 (***(May not be applicable for Honda / Acura)***)
P1533 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 2 (***(May not be applicable for Honda / Acura)***)
P1534 "B" Camshaft Position Actuator Control Circuit Signal High Bank 2 (***(May not be applicable for Honda / Acura)***)
P1537 Fuel Cut-off Valve Incorrect Function (***(May not be applicable for Honda / Acura)***)
P1538 Fuel Cut-off Valve Open/Short To Ground (***(May not be applicable for Honda / Acura)***)
P1540 Pedal Position Sensor (***(May not be applicable for Honda / Acura)***)
P1540 VSS Signal Too High (***(May not be applicable for Honda / Acura)***)
P1541 Pedal Position Sensor Double Error (***(May not be applicable for Honda / Acura)***)
P1542 Pedal Position Sensor Electrical (***(May not be applicable for Honda / Acura)***)
P1543 Pedal Position Sensor (***(May not be applicable for Honda / Acura)***)
P1544 Pedal Position Sensor (***(May not be applicable for Honda / Acura)***)
P1545 Pedal Position Sensor (***(May not be applicable for Honda / Acura)***)
P1546 Pedal Position Sensor (***(May not be applicable for Honda / Acura)***)
P1546 Air Conditioning (A/C) Clutch Relay Control Circuit (***(May not be applicable for Honda / Acura)***)
P1546 Wastegate Bypass Regulator Valve Short To Positive (***(May not be applicable for Honda / Acura)***)
P1549 Intake Manifold Control Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1549 Wastegate Bypass Regulator Valve Open/Short To Ground (***(May not be applicable for Honda / Acura)***)
P1550 Idle Speed Control valve Closing Solenoid Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1550 PSP Sensor Malfunction (***(May not be applicable for Honda / Acura)***)
P1550 Charge Pressure Control Difference (***(May not be applicable for Honda / Acura)***)
P1551 "A" Camshaft Position Actuator Control Open Circuit Bank 1 (***(May not be applicable for Honda / Acura)***)
P1552 "A" Camshaft Position Actuator Control Open Circuit Bank 1 (***(May not be applicable for Honda / Acura)***)
P1554 Cruise Engaged Circuit High Vol***e
P1556 "A" Camshaft Position Actuator Control Open Circuit Bank 1 (***(May not be applicable for Honda / Acura)***)
P1560 Cruise Control System-Transaxle Not in Drive
P1560 "B" Camshaft Position Actuator Control Open Circuit Bank 1 (***(May not be applicable for Honda / Acura)***)
P1560 Back-Up Vol***e Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1561 Quantity Adjuster Control Difference (***(May not be applicable for Honda / Acura)***)
P1562 Quantity Adjuster Upper Stop Value (***(May not be applicable for Honda / Acura)***)
P1563 Quantity Adjuster Lower Stop Value (***(May not be applicable for Honda / Acura)***)
P1564 Cruise Control System-Vehicle Acceleration too high
P1564 Control Module Selection (***(May not be applicable for Honda / Acura)***)
P1565 "B" Camshaft Position Actuator Control Open Circuit Bank 1 (***(May not be applicable for Honda / Acura)***)
P1566 Cruise Control System-Engine RPM Too High
P1567 Cruise Control- ABCS Active
P1569 "A" Camshaft Position Actuator Control Open Circuit Bank 2 (***(May not be applicable for Honda / Acura)***)
P1570 Cruise Control System - Traction Control Active
P1571 Traction Control System PWM Circuit No Frequency
P1572 Brake Pedal Switch Circuit (***(May not be applicable for Honda / Acura)***)
P1574 EBTCM System- Stop Lamp Switch Circuit High Vol***e
P1575 Extended Travel Brake Switch Circuit High Vol***e
P1579 Park/Neutral to Drive/Reverse At high Throttle Angle
P1580 Throttle Valve Mechanically Stuck (***(May not be applicable for Honda / Acura)***)
P1581 "B" Camshaft Position Actuator Control Open Circuit Bank 2 (***(May not be applicable for Honda / Acura)***)
P1585 Cruise Control Inhibit Output Circuit (***(May not be applicable for Honda / Acura)***)
P1589 Control Module Self Test, Knock Control Test Pulse Bank 1 (***(May not be applicable for Honda / Acura)***)
P1590 Neutral Position Switch Circuit High Input (***(May not be applicable for Honda / Acura)***)
P1591 Neutral Position Switch Circuit Low Input (***(May not be applicable for Honda / Acura)***)
P1593 DISA Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1594 "B" Camshaft Position Actuator Control Open Circuit Bank 2 (***(May not be applicable for Honda / Acura)***)
P1594 Charging System Vol***e Too High (***(May not be applicable for Honda / Acura)***)
P1594 AT Diagnosis Input Signal Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1595 Speed Control Solenoid Circuits (***(May not be applicable for Honda / Acura)***)
P1595 AT Diagnosis Input Signal Circuit Low Input (***(May not be applicable for Honda / Acura)***)
P1596 Speed Control Switch always High (***(May not be applicable for Honda / Acura)***)
P1596 AT Diagnosis Input Signal Circuit High Input (***(May not be applicable for Honda / Acura)***)
P1597 Speed Control Switch always Low (***(May not be applicable for Honda / Acura)***)
P1598 A/C Pressure Sensor Volts Too High (***(May not be applicable for Honda / Acura)***)
P1599 A/C Pressure Sensor Volts Too Low (***(May not be applicable for Honda / Acura)***)
P1599 Engine Stall or Near Stall Detected
P1600 Battery Vol***e SRC High Exceeded (***(May not be applicable for Honda / Acura)***)
P1600 ECM BATT Malfunction (***(May not be applicable for Honda / Acura)***)
P1600 Supply Vol***e Too Low (***(May not be applicable for Honda / Acura)***)
P1602 Loss of EBTCM Serial Data
P1602 Control Module Self Test, Control Module Defective (***(May not be applicable for Honda / Acura)***)
P1602 PCM Not Programmed (***(May not be applicable for Honda / Acura)***)
P1603 Loss of SDM Serial Data
P1603 Control Module Self Test, Torque Monitoring (***(May not be applicable for Honda / Acura)***)
P1603 Battery Backup Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1604 Loss of IPC Serial Data
P1604 Control Module Self Test, Speed Monitoring (***(May not be applicable for Honda / Acura)***)
P1605 Loss of HVACC Serial Data
P1605 Keep Alive Memory Failure (***(May not be applicable for Honda / Acura)***)
P1605 Powertrain Control Module (***(May not be applicable for Honda / Acura)***)
P1605 A/T Diagnosis Communication Line (***(May not be applicable for Honda / Acura)***)
P1607 Malfunction In PCM Internal Circuit
P1607 CAN Version (***(May not be applicable for Honda / Acura)***)
P1607 Electronic Throttle System Communication Error (***(May not be applicable for Honda / Acura)***)
P1608 Serial Communicating Link Control Module (***(May not be applicable for Honda / Acura)***)
P1609 Serial Communicating Link EML (***(May not be applicable for Honda / Acura)***)
P1610 Loss of PZM Serial Data
P1610 Immobilizer Function (***(May not be applicable for Honda / Acura)***)
P1611 Loss of CVRTD Serial Data
P1611 Serial Communicating Link Transmission Control Module (***(May not be applicable for Honda / Acura)***)
P1612 Engine Control Module Incorrectly Coded (***(May not be applicable for Honda / Acura)***)
P1614 Electronic Throttle System Module Malfunction (***(May not be applicable for Honda / Acura)***)
P1616 Glow Plug Indicator Lamp Short To Positive (***(May not be applicable for Honda / Acura)***)
P1617 Engine Oil Level Switch Circuit
P1617 Glow Plug Indicator Lamp Open/Short To Ground (***(May not be applicable for Honda / Acura)***)
P1618 Glow Plug Relay Short To Positive (***(May not be applicable for Honda / Acura)***)
P1619 MAP Cooling Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1619 Glow Plug Relay Open/Short To Ground (***(May not be applicable for Honda / Acura)***)
P1620 MAP Cooling Control Circuit Signal High (***(May not be applicable for Honda / Acura)***)
P1621 PCM Memory Performance
P1622 MAP Cooling Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1623 Pedal Position Sensor Potentiometer Supply (***(May not be applicable for Honda / Acura)***)
P1624 Pedal Position Sensor Potentiometer Supply Channel 1 Electrical (***(May not be applicable for Honda / Acura)***)
P1624 Customer Snapshot Requested - Data Available (***(May not be applicable for Honda / Acura)***)
P1625 Pedal Position Sensor Potentiometer Supply Channel 2 Electrical (***(May not be applicable for Honda / Acura)***)
P1626 Theft Deterrent System - Fuel Enable Circuit
P1626 Implausible Signal From Transmission Control Module (***(May not be applicable for Honda / Acura)***)
P1630 Theft Deterrent - PCM in Learn Mode
P1631 Theft Deterrent - Password Incorrect
P1631 Throttle Position Sensor Signal Too High (***(May not be applicable for Honda / Acura)***)
P1632 Theft Deterrent - Fuel Disabled
P1632 Throttle Valve Adaptation; Adaptation Condition Not Met (***(May not be applicable for Honda / Acura)***)
P1632 Traction Control System Malfunction (***(May not be applicable for Honda / Acura)***)
P1632 Throttle Position Sensor Supply Vol***e (***(May not be applicable for Honda / Acura)***)
P1633 Ignition Supplement Power Circuit Low Vol***e
P1633 Throttle Valve Adaptation; Limp Home Position (***(May not be applicable for Honda / Acura)***)
P1633 Keep Alive Power Vol***e Too Low (***(May not be applicable for Honda / Acura)***)
P1634 Ignition 1 Power Circuit Low Vol***e
P1634 Throttle Valve Adaptation; Spring Test Failed (***(May not be applicable for Honda / Acura)***)
P1635 Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted (***(May not be applicable for Honda / Acura)***)
P1635 5 Volt Reference Circuit (***(May not be applicable for Honda / Acura)***)
P1635 Tire/Axle Out Of Acceptable Range (***(May not be applicable for Honda / Acura)***)
P1636 Throttle Valve Control Circuit (***(May not be applicable for Honda / Acura)***)
P1636 Inductive Signiture Chip Communication Error (***(May not be applicable for Honda / Acura)***)
P1637 Throttle Valve Position Control; Control Deviation (***(May not be applicable for Honda / Acura)***)
P1638 Throttle Valve Position Control; Throttle Stuck Temporarily (***(May not be applicable for Honda / Acura)***)
P1639 Throttle Valve Position Control; Throttle Stuck Permanently (***(May not be applicable for Honda / Acura)***)
P1639 5 Volt Reference 2 Circuit (***(May not be applicable for Honda / Acura)***)
P1639 Vehicle ID Block Not Programmed Or Corrupt (***(May not be applicable for Honda / Acura)***)
P1639 Throttle Position Sensor Implausible Signal (***(May not be applicable for Honda / Acura)***)
P1640 Internal Control Module (ROM/RAM) Error (***(May not be applicable for Honda / Acura)***)
P1640 DTC's Available In Another Module (***(May not be applicable for Honda / Acura)***)
P1640 Driver 1 - Input High Vol***e
P1640 Engine Control Module Inoperative (***(May not be applicable for Honda / Acura)***)
P1641 Malfunction Indicator Lamp (MIL) Control Circuit
P1642 Vehicle Speed Output Circuit
P1644 Delivered Torque Output Circuit
P1645 EVAP Solenoid Output Circuit
P1646 EVAP Vent Valve Output Circuit
P1648 CAN-Bus System Component Failure (***(May not be applicable for Honda / Acura)***)
P1649 Implausible Signal From ABS Control Module (***(May not be applicable for Honda / Acura)***)
P1650 Driver 2 - Input High Vol***e
P1650 Power Steering Pressure Switch Malfunction (***(May not be applicable for Honda / Acura)***)
P1650 Power Steering Pressure Switch Out Of Range (***(May not be applicable for Honda / Acura)***)
P1651 Power Steering Pressure Switch Input Malfunction (***(May not be applicable for Honda / Acura)***)
P1651 Power Steering Pressure Switch Signal Malfunction (***(May not be applicable for Honda / Acura)***)
P1652 Lift/Dive Circuit
P1654 Cruise Disable Output Circuit
P1656 Automatic Transaxle
P1660 Cooling Fan Control Circuits
P1660 A/T FI Data Line Failure
P1670 ODM has Detected a Vol***e greater than 33 volts (***(May not be applicable for Honda / Acura)***)
P1676 FPTDR Signal Failure
P1678 FPTDR Signal Line Failure
P1680 Clutch Released Switch Circuit (***(May not be applicable for Honda / Acura)***)
P1681 No I/P Cluster CCD/J1850 Messages Received (***(May not be applicable for Honda / Acura)***)
P1681 A/T FI Signal A Low Input
P1682 A/T FI Signal A High Input
P1682 Charging System Vol***e Too Low (***(May not be applicable for Honda / Acura)***)
P1683 Speed Control Power Relay or S/C 12V Driver Circuit (***(May not be applicable for Honda / Acura)***)
P1684 Battery Disconnected Within Last 50 Starts (***(May not be applicable for Honda / Acura)***)
P1685 Skim Invalid Key (***(May not be applicable for Honda / Acura)***)
P1686 No SKIM Bus Message Received (***(May not be applicable for Honda / Acura)***)
P1686 A/T FI Signal B Low Input
P1687 A/T FI Signal B High Input
P1687 No Cluster Bus Message (***(May not be applicable for Honda / Acura)***)
P1689 Traction Control Delivered Torque Output Circuit (***(May not be applicable for Honda / Acura)***)
P1690 Malfunction Indicator Lamp (MIL) Electrical (***(May not be applicable for Honda / Acura)***)
P1693 DTC Detected In Companion Mode (***(May not be applicable for Honda / Acura)***)
P1694 Fault In Companion Mode (***(May not be applicable for Honda / Acura)***)
P1695 No CCD/J185O Message From BCM (***(May not be applicable for Honda / Acura)***)
P1696 PCM Failure EEPROM Write Denied (***(May not be applicable for Honda / Acura)***)
P1697 PCM Failure SRI Mile Not Stored (***(May not be applicable for Honda / Acura)***)
P1698 No Bus Message From TCM (***(May not be applicable for Honda / Acura)***)
P1698 Engine Torque Control Cut Signal Circuit Low Input (***(May not be applicable for Honda / Acura)***)
P1699 Engine Torque Control Cut Signal Circuit High Input (***(May not be applicable for Honda / Acura)***)
P1700 TPS Circuit Malfunction For AT (***(May not be applicable for Honda / Acura)***)
P1701 Transmission Solenoid Malfunction (***(May not be applicable for Honda / Acura)***)
P1701 Cruise Control Set Signal Circuit Malfunction For AT (***(May not be applicable for Honda / Acura)***)
P1703 Brake On/Off Switch (***(May not be applicable for Honda / Acura)***)
P1703 Brake On/Off Switch Out Of Range (***(May not be applicable for Honda / Acura)***)
P1703 Low Clutch Timing Control Solenoid Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1705 Automatic Transaxle
P1705 Transmisson Range Sensor Out Of Range (***(May not be applicable for Honda / Acura)***)
P1705 Transmisson Range Sensor (***(May not be applicable for Honda / Acura)***)
P1705 Throttle Position Sensor ((***(May not be applicable for Honda / Acura)***))
P1706 Automatic Transaxle
P1706 Park/Neutral Position (PNP) Switch (***(May not be applicable for Honda / Acura)***)
P1709 Automatic Transaxle
P1709 Park/Neutral Position Switch Out Of Range (***(May not be applicable for Honda / Acura)***)
P1710 Automatic Transaxle
P1711 Transmission Fluid Temperature Sensor (***(May not be applicable for Honda / Acura)***)
P1711 Engine Torque Control Signal 1 Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1712 Engine Torque Control Signal 2 Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1713 Automatic Transaxle
P1719 Skip Shift Solenoid Circuit (***(May not be applicable for Honda / Acura)***)
P1729 4x4 Low Switch Malfunction (***(May not be applicable for Honda / Acura)***)
P1734 Pressure Control Solenoid "B" Electrical (***(May not be applicable for Honda / Acura)***)
P1738 Automatic Transaxle
P1738 Pressure Control Solenoid "C" Electrical (***(May not be applicable for Honda / Acura)***)
P1739 Automatic Transaxle
P1740 Automatic Transaxle
P1743 Pressure Control Solenoid "E" Electrical (***(May not be applicable for Honda / Acura)***)
P1744 Pressure Control Solenoid "A" Electrical (***(May not be applicable for Honda / Acura)***)
P1746 EPC Solenoid Failed Low (***(May not be applicable for Honda / Acura)***)
P1746 Transmission Control Module Output S***e (***(May not be applicable for Honda / Acura)***)
P1747 CAN Bus Monitoring (***(May not be applicable for Honda / Acura)***)
P1747 EPC Solenoid Short Circuit (***(May not be applicable for Honda / Acura)***)
P1748 Transmission Control Module Self Test (***(May not be applicable for Honda / Acura)***)
P1749 Secondary Pressure Solenoid Communication Error (***(May not be applicable for Honda / Acura)***)
P1749 EPC Solenoid Open Circuit (***(May not be applicable for Honda / Acura)***)
P1750 Secondary Pressure Solenoid Circuit Range/Performance (***(May not be applicable for Honda / Acura)***)
P1751 Secondary Pressure Solenoid Open Circuit (***(May not be applicable for Honda / Acura)***)
P1751 Shift Solenoid #1 (SS1) (***(May not be applicable for Honda / Acura)***)
P1751 A/T Control Relay Malfunction (***(May not be applicable for Honda / Acura)***)
P1753 Automatic Transaxle
P1754 Coast Clutch Solenoid (***(May not be applicable for Honda / Acura)***)
P1756 GOV Press Not Equal To Target @ 15-20 PSI (***(May not be applicable for Honda / Acura)***)
P1756 Shift Solenoid #2 (SS2) (***(May not be applicable for Honda / Acura)***)
P1757 GOV Press Not Equal To Target @ 15-20 PSI (***(May not be applicable for Honda / Acura)***)
P1758 Automatic Transaxle
P1760 Overrun Clutch Solenoid Valve (***(May not be applicable for Honda / Acura)***)
P1761 Shift Solenoid Malfunction (***(May not be applicable for Honda / Acura)***)
P1761 Shift Solenoid #3 (SS3) (***(May not be applicable for Honda / Acura)***)
P1762 Gov Press Sen Offset Volts Too Low or high(***(May not be applicable for Honda / Acura)***)P1763 Governor Pressure Sensor Volts Too High (***(May not be applicable for Honda / Acura)***)
P1764 Governor Pressure Sensor Volts Too Low (***(May not be applicable for Honda / Acura)***)
P1765 CAN Throttle Valve (***(May not be applicable for Honda / Acura)***)
P1765 Trans 12 Volt Supply Relay CTRL Circuit (***(May not be applicable for Honda / Acura)***)
P1768 Automatic Transaxle
P1770 CAN Torque Interface (***(May not be applicable for Honda / Acura)***)
P1773 Automatic Transaxle
P1778 Automatic Transaxle
P1780 CAN Torque Reduction (***(May not be applicable for Honda / Acura)***)
P1780 Transmission Control Switch (***(May not be applicable for Honda / Acura)***)
P1780 Transmission Control Switch Out Of Range(***(May not be applicable for Honda / Acura)***)
P1780 Park/Neutral Position Switch Malfunction (Only For A/T) (***(May not be applicable for Honda / Acura)***)
P1781 4x4 Switch Out Of Range (***(May not be applicable for Honda / Acura)***)
P1783 Transmission Over Temperature Condition (***(May not be applicable for Honda / Acura)***)
P1786 Automatic Transaxle
P1790 Automatic Transaxle
P1791 Automatic Transaxle
P1792 Automatic Transaxle
P1794 Automatic Transaxle
P1810 TFP Valve Position Switch Circuit (***(May not be applicable for Honda / Acura)***)
P1811 Maximum Adapt and Long Shift (***(May not be applicable for Honda / Acura)***)
P1819 Internal Mode Switch - No Start/Wrong Range (***(May not be applicable for Honda / Acura)***)
P1820 Internal Mode Switch Circuit A Low (***(May not be applicable for Honda / Acura)***)
P1822 Internal Mode Switch Circuit B High (***(May not be applicable for Honda / Acura)***)
P1823 Internal Mode Switch Circuit P Low (***(May not be applicable for Honda / Acura)***)
P1825 Internal Mode Switch - Invalid Range (***(May not be applicable for Honda / Acura)***)
P1826 Internal Mode Switch Circuit C High (***(May not be applicable for Honda / Acura)***)
P1851 Implausible Signal From ABS Control Module (***(May not be applicable for Honda / Acura)***)
P1854 Drive Train CAN-Bus Inoperative (***(May not be applicable for Honda / Acura)***)
P1860 TCC PWM Solenoid Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1887 TCC Release Switch Circuit (***(May not be applicable for Honda / Acura)***)
P1899 Park/Neutral Position Switch Stuck In Park or In Gear (***(May not be applicable for Honda / Acura)***)
P1900 Output Shaft Speed Sensor Circuit Failure (***(May not be applicable for Honda / Acura)***)
P2008 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit
P2009 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Vol***e
P2010 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Vol***e
P2066 Fuel Level Sensor 2 Performance
P2067 Fuel Level Sensor 2 Circuit Low Vol***e
P2068 Fuel Level Sensor 2 Circuit High Vol***e
P2096 or P2098 Post Catalyst Fuel Trim System Low Limit
P2097 or P2099 Post Catalyst Fuel Trim System High Limit
P2100 Throttle Actuator Control (TAC) Motor Control Circuit
P2101 Control Module Throttle Actuator Position Performance
P2105 Throttle Actuator Control (TAC) System - Forced Engine Shutdown
P2107 Throttle Actuator Control (TAC) Module Internal Circuit
P2119 Throttle Closed Position Performance
P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Vol***e
P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Vol***e
P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Vol***e
P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Vol***e
P2135 Throttle Position (TP) Sensor 1-2 Correlation
P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
P2176 Minimum Throttle Position Not Learned
P2500 Generator L-Terminal Circuit Low Vol***e
P2501 Generator L-Terminal Circuit High Vol
