رقم العضوية : 131307
السيارة: .
السيارة[2]: E46
الجزء الثالث عشر :
71100212 Compressor, instant mobility set Permanent failure
711002XX Compressor, instant mobility set
71100366 Sealing gel, instant mobility set No effect
711003XX Sealing gel, instant mobility set
7110XXXX On-board equipment
71110001 Tool box / tool bag Cracked / broken / torn off
71110032 Tool box / tool bag Deformed / distorted / bent
71110037 Tool box / tool bag Loose
711100XX Tool box / tool bag
71110101 Toolkit retaining strap Cracked / broken / torn off
711101XX Toolkit retaining strap
7111XXXX Tools
71120012 Vehicle jack Permanent failure
711200XX Vehicle jack
7112XXXX Vehicle jack
71600131 Trailer tow hitch Excessive play
71600134 Trailer tow hitch Stiff to move
71600137 Trailer tow hitch Loose
716001XX Trailer tow hitch
7160XXXX Various accessories
71XXXXXX Accessories for engine and chassis
72110029 Front seat belts Sticking/jammed
72110039 Front seat belts Unpleasant noises
72110065 Front seat belts Does not lock into position
72110069 Front seat belts Worn / sheared through
721100XX Front seat belts
72110129 Rear seat belts Sticking/jammed
72110139 Rear seat belts Unpleasant noises
72110165 Rear seat belts Does not lock into position
721101XX Rear seat belts
72110339 Seat belt catches, front Unpleasant noises
72110352 Seat belt catches, front Not opening
72110353 Seat belt catches, front Not closing
721103XX Seat belt catches, front
72110429 Seat belt height adjustment Sticking/jammed
72110439 Seat belt height adjustment Unpleasant noises
721104XX Seat belt height adjustment
72110639 Seat belt catches, rear Unpleasant noises
72110652 Seat belt catches, rear Not opening
72110653 Seat belt catches, rear Not closing
721106XX Seat belt catches, rear
72110715 Belt tensioner/belt buckle tensioner Permanent malfunction
72110779 Belt tensioner/belt buckle tensioner incorrect connection /contact
72110780 Belt tensioner/belt buckle tensioner short circuit
721107XX Belt tensioner/belt buckle tensioner
72110813 Catch tongue stopper for front seat belt Broken
721108XX Catch tongue stopper for front seat belt
72110979 Lock contact, rear head restraint adjustment incorrect connection /contact
721109XX Lock contact, rear head restraint adjustment
72111108 Seat belt height adjustment, operating cable Jumps out
721111XX Seat belt height adjustment, operating cable
72119339 E53 Clicking noise from seat belt mounting at B-pillar
7211XXXX Safety belts
72600014 Other accessories Occasional malfunction
72600015 Other accessories Permanent malfunction
726000XX Other accessories
72600203 Ski bag Ripped
72600229 Ski bag Sticking/jammed
72600239 Ski bag Unpleasant noises
72600265 Ski bag Does not lock into position
726002XX Ski bag
72600339 First aid kit Unpleasant noises
726003XX First aid kit
72604948 Z3 / Z4 case (for boot rack) Leaking
72604952 Z3 / Z4 case (for boot rack) Not opening
72604953 Z3 / Z4 case (for boot rack) Not closing
72604965 Z3 / Z4 case (for boot rack) Does not lock into position
726049XX Z3 / Z4 case (for boot rack)
72605001 Rack system Cracked / broken / torn off
72605013 Rack system Broken
72605022 Rack system Manufacturing fault
72605029 Rack system Sticking/jammed
72605066 Rack system No effect
72605078 Rack system poor surface finish
726050XX Rack system
72605201 Wind guard (convertible) Cracked / broken / torn off
72605222 Wind guard (convertible) Manufacturing fault
72605257 Wind guard (convertible) Vibration / oscillation
72605265 Wind guard (convertible) Does not lock into position
72605268 Wind guard (convertible) Peels off / detaches itself
72605278 Wind guard (convertible) poor surface finish
726052XX Wind guard (convertible)
72605313 Mud flap/splash guard Broken
72605341 Mud flap/splash guard Poorly adapted/fitted
726053XX Mud flap/splash guard
72605407 Rear trim panel Cracked
72605430 Rear trim panel Blistering
72605441 Rear trim panel Poorly adapted/fitted
72605467 Rear trim panel Discoloured
726054XX Rear trim panel
72605548 Reserve canister Leaking
72605575 Reserve canister corroded
72605578 Reserve canister poor surface finish
726055XX Reserve canister
72605632 Cool box (portable) Deformed / distorted / bent
72605648 Cool box (portable) Leaking
72605666 Cool box (portable) No effect
726056XX Cool box (portable)
72605715 Hardtop lift Permanent malfunction
72605775 Hardtop lift corroded
72605778 Hardtop lift poor surface finish
726057XX Hardtop lift
72605801 Roof box Cracked / broken / torn off
72605829 Roof box Sticking/jammed
72605830 Roof box Blistering
72605850 Roof box Water ingress / condensate
72605853 Roof box Not closing
72605878 Roof box poor surface finish
726058XX Roof box
72605901 Rear compartment protective cover Cracked / broken / torn off
72605922 Rear compartment protective cover Manufacturing fault
726059XX Rear compartment protective cover
72606401 Seat covers Cracked / broken / torn off
72606403 Seat covers Ripped
72606422 Seat covers Manufacturing fault
72606467 Seat covers Discoloured
726064XX Seat covers
72606601 Luggage compartment-floor net Cracked / broken / torn off
726066XX Luggage compartment-floor net
72606701 Snow chains Cracked / broken / torn off
72606722 Snow chains Manufacturing fault
726067XX Snow chains
72606807 Caravan outside mirror Cracked
72606833 Caravan outside mirror Optical distortion
72606845 Caravan outside mirror Not controllable/adjustable
72606857 Caravan outside mirror Vibration / oscillation
72606878 Caravan outside mirror poor surface finish
726068XX Caravan outside mirror
72607022 Tow bar/tow rope Manufacturing fault
72607075 Tow bar/tow rope corroded
72607078 Tow bar/tow rope poor surface finish
726070XX Tow bar/tow rope
72607122 Shift lever lock Manufacturing fault
72607134 Shift lever lock Stiff to move
72607157 Shift lever lock Vibration / oscillation
72607165 Shift lever lock Does not lock into position
726071XX Shift lever lock
72607330 Decorative strips Blistering
72607367 Decorative strips Discoloured
72607368 Decorative strips Peels off / detaches itself
726073XX Decorative strips
72608017 Luggage compartment pan/formed mat Odour
72608022 Luggage compartment pan/formed mat Manufacturing fault
72608032 Luggage compartment pan/formed mat Deformed / distorted / bent
726080XX Luggage compartment pan/formed mat
72608122 Exhaust pipe extension Manufacturing fault
72608141 Exhaust pipe extension Poorly adapted/fitted
72608178 Exhaust pipe extension poor surface finish
726081XX Exhaust pipe extension
7260XXXX Various accessories
72XXXXXX Accessories, body
84110102 Transceiver unit Software error / internal device fault
84110104 Transceiver unit Screw connection torn
84110111 Transceiver unit Occasional failure
84110112 Transceiver unit Permanent failure
84110114 Transceiver unit Occasional malfunction
841101XX Transceiver unit
84110214 BMW ASSIST (online service) Occasional malfunction
84110215 BMW ASSIST (online service) Permanent malfunction
84110218 BMW ASSIST (online service) Incorrect/incomplete reading
841102XX BMW ASSIST (online service)
84110414 Keypad handset/mobile phone Occasional malfunction
84110415 Keypad handset/mobile phone Permanent malfunction
84110429 Keypad handset/mobile phone Sticking/jammed
84110465 Keypad handset/mobile phone Does not lock into position
84110479 Keypad handset/mobile phone incorrect connection /contact
841104XX Keypad handset/mobile phone
84110512 Telephone rechargeable battery (mobile phone) Permanent failure
841105XX Telephone rechargeable battery (mobile phone)
84110865 Keypad handset support Does not lock into position
841108XX Keypad handset support
84111014 Phone board Occasional malfunction
84111015 Phone board Permanent malfunction
84111029 Phone board Sticking/jammed
84111065 Phone board Does not lock into position
84111079 Phone board incorrect connection /contact
841110XX Phone board
84111202 Card reader Software error / internal device fault
84111211 Card reader Occasional failure
84111212 Card reader Permanent failure
84111229 Card reader Sticking/jammed
84111283 Card reader incorrect or no switching action
841112XX Card reader
84111429 Card reader eject lever Sticking/jammed
841114XX Card reader eject lever
84111514 Keypad handset display Occasional malfunction
84111515 Keypad handset display Permanent malfunction
84111518 Keypad handset display Incorrect/incomplete reading
84111586 Keypad handset display does not light up
841115XX Keypad handset display
84111614 Keypad handset controls Occasional malfunction
84111615 Keypad handset controls Permanent malfunction
84111629 Keypad handset controls Sticking/jammed
84111686 Keypad handset controls does not light up
841116XX Keypad handset controls
84111729 Keypad handset eject button Sticking/jammed
84111786 Keypad handset eject button does not light up
841117XX Keypad handset eject button
84111811 Eject box Occasional failure
84111812 Eject box Permanent failure
84111886 Eject box does not light up
841118XX Eject box
84111911 Telephone interface Occasional failure
84111912 Telephone interface Permanent failure
841119XX Telephone interface
84112114 Telephone, hands-free Occasional malfunction
84112115 Telephone, hands-free Permanent malfunction
84112139 Telephone, hands-free Unpleasant noises
841121XX Telephone, hands-free
84112212 Telephone, incoming call Permanent failure
84112214 Telephone, incoming call Occasional malfunction
84112215 Telephone, incoming call Permanent malfunction
84112239 Telephone, incoming call Unpleasant noises
841122XX Telephone, incoming call
84112312 Telephone, outgoing call Permanent failure
84112314 Telephone, outgoing call Occasional malfunction
84112315 Telephone, outgoing call Permanent malfunction
84112339 Telephone, outgoing call Unpleasant noises
841123XX Telephone, outgoing call
84112514 Voice entry control unit (SES) Occasional malfunction
84112515 Voice entry control unit (SES) Permanent malfunction
841125XX Voice entry control unit (SES)
84114022 Telephone console, mobile phone Manufacturing fault
84114037 Telephone console, mobile phone Loose
84114039 Telephone console, mobile phone Unpleasant noises
84114041 Telephone console, mobile phone Poorly adapted/fitted
84114065 Telephone console, mobile phone Does not lock into position
841140XX Telephone console, mobile phone
84114111 Mobile phone charging/hands-free electronics Occasional failure
84114112 Mobile phone charging/hands-free electronics Permanent failure
84114179 Mobile phone charging/hands-free electronics incorrect connection /contact
841141XX Mobile phone charging/hands-free electronics
84114214 Line compensator Occasional malfunction
84114215 Line compensator Permanent malfunction
84114237 Line compensator Loose
841142XX Line compensator
84119002 E38 E39 E46 E52 E53 Motorola telephone - system cutout
84119014 E38 E39 E46 E53 Motorola mobile phone - audio loss
84119074 E38 E39 E46 E53 Overheating of Motorola V3690 mobile phone
84119086 E65 E66 Phone board lighting defective
84119102 E39 E53 CPT 8000 Telephone discharges vehicle battery
84119112 E38 E39 E46 E53 Motorola mobile phone - system cutout
84119266 E38 E39 E46 E53 Motorola fixed installation telephone - MFL inoperative
84119383 E38 E39 E46 Telephone mute occasionally inactive (Nokia mobile phone)
84119420 E39 E53 Fixed Siemens telephone - increased closed-circuit current
84119583 E38 E39 E46 E53 Telephone (SA 629, 632) mute occasionally active after receiving SMS
84119615 E38 E39 E53 Fixed Siemens telephone - cutout timer inoperative
84119783 E65 (With SE 630) Telephone handset batteries are being drained
84119802 E38 E39 E46 E53 (SA 630) Siemens stationary-mounted telephone various fault patterns (interface)
84119914 E38 E39 E46 E53 Motorola mobile phone - call termination
8411XXXX Car telephone
84120101 Connecting wire (transceiver keypad handset) Cracked / broken / torn off
84120179 Connecting wire (transceiver keypad handset) incorrect connection /contact
841201XX Connecting wire (transceiver keypad handset)
84120401 Telephone aerial lead Cracked / broken / torn off
84120479 Telephone aerial lead incorrect connection /contact
84120480 Telephone aerial lead short circuit
841204XX Telephone aerial lead
8412XXXX Lines/wires (connecting wire/antenna lead)
84310102 Hands-free telephone microphone Software error / internal device fault
84310111 Hands-free telephone microphone Occasional failure
84310112 Hands-free telephone microphone Permanent failure
84310137 Hands-free telephone microphone Loose
84310139 Hands-free telephone microphone Unpleasant noises
843101XX Hands-free telephone microphone
84310411 Telephone speaker Occasional failure
84310412 Telephone speaker Permanent failure
84310437 Telephone speaker Loose
84310439 Telephone speaker Unpleasant noises
843104XX Telephone speaker
8431XXXX Microphone, speaker
84320101 Line, hands-free micro/speaker Cracked / broken / torn off
84320179 Line, hands-free micro/speaker incorrect connection /contact
843201XX Line, hands-free micro/speaker
8432XXXX Hands-free telephone lines
84500137 Antenna, car telephone Loose
84500166 Antenna, car telephone No effect
84500175 Antenna, car telephone corroded
845001XX Antenna, car telephone
84500266 Bluetooth antenna No effect
84500279 Bluetooth antenna incorrect connection /contact
845002XX Bluetooth antenna
8450XXXX Antenna, car telephone
84XXXXXX Communication systems
86120122 Carrier frame/floor/bottom section Manufacturing fault
86120178 Carrier frame/floor/bottom section poor surface finish
861201XX Carrier frame/floor/bottom section
86120229 Mounting bracket Sticking/jammed
86120241 Mounting bracket Poorly adapted/fitted
861202XX Mounting bracket
86120334 Towing hitch/towbar Stiff to move
86120365 Towing hitch/towbar Does not lock into position
86120378 Towing hitch/towbar poor surface finish
861203XX Towing hitch/towbar
86120434 Support Stiff to move
86120478 Support poor surface finish
861204XX Support
86120513 Spring/damper Broken
86120548 Spring/damper Leaking
861205XX Spring/damper
86120622 Wheels/wheel cap Manufacturing fault
86120678 Wheels/wheel cap poor surface finish
861206XX Wheels/wheel cap
86120727 Brake unit Locked/jammed
86120739 Brake unit Unpleasant noises
86120740 Brake unit Poorly adjusted / outside tolerance
861207XX Brake unit
86120867 Plastic parts/ram guard Discoloured
86120878 Plastic parts/ram guard poor surface finish
861208XX Plastic parts/ram guard
86120907 Lights/spot lights/wiring harness Cracked
86120912 Lights/spot lights/wiring harness Permanent failure
86120937 Lights/spot lights/wiring harness Loose
86120979 Lights/spot lights/wiring harness incorrect connection /contact
861209XX Lights/spot lights/wiring harness
8612XXXX Trailer platform, braked
86200148 Hood/flaps Leaking
86200152 Hood/flaps Not opening
86200153 Hood/flaps Not closing
86200165 Hood/flaps Does not lock into position
86200167 Hood/flaps Discoloured
86200178 Hood/flaps poor surface finish
862001XX Hood/flaps
86200241 Motorcycle module/loading ramp Poorly adapted/fitted
86200265 Motorcycle module/loading ramp Does not lock into position
86200278 Motorcycle module/loading ramp poor surface finish
862002XX Motorcycle module/loading ramp
8620XXXX Attachments
86XXXXXX Trailer
P Codes:
P0010 A Camshaft Position Actuator Circuit (Bank 1)
P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1))
P0012 A Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 B Camshaft Position - Actuator Circuit (Bank 1)
P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015 B Camshaft Position - Timing Over-Retarded (Bank 1)
P0016 Crankshaft/Camshaft Timing Misalignment A rationality error has been detected for camshaft position out of phase with crankshaft.
P0020 A Camshaft Position Actuator Circuit (Bank 2)
P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 B Camshaft Position - Actuator Circuit (Bank 2)
P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025 B Camshaft Position - Timing Over-Retarded (Bank 2)
P0030 HO2S Heater Control Circuit Bank 1 Sensor 1
P0031 HO2S Heater Circuit Low Vol***e Bank 1 Sensor 1
P0032 HO2S Heater Circuit High Vol***e Bank 1 Sensor 1
P0036 HO2S Heater Control Circuit Bank 1 Sensor 2
P0037 HO2S Heater Circuit Low Vol***e Bank 1 Sensor 2
P0038 HO2S Heater Circuit High Vol***e Bank 1 Sensor 2
P0050 HO2S Heater Circuit Bank 2 Sensor 1
P0051 HO2S Heater Circuit Low Vol***e Bank 2 Sensor 1
P0052 HO2S Heater Circuit High Vol***e Bank 2 Sensor 1
P0056 HO2S Heater Circuit Bank 2 Sensor 2
P0057 HO2S Heater Circuit Low Vol***e Bank 2 Sensor 2
P0058 HO2S Heater Circuit High Vol***e Bank 2 Sensor 2
P0100 Mass or Volume Air Flow Circuit Malfunction Insufficient Activity
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0128 Range/Performance Problem In Thermostat
P0129 UNKNOWN CODE
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Vol***e (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Vol***e (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Vol***e (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Vol***e (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Vol***e (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Vol***e (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0148 UNKNOWN CODE
P0149 UNKNOWN CODE
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Vol***e (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Vol***e (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Vol***e (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Vol***e (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Vol***e (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Vol***e (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0168 UNKNOWN CODE
P0169 UNKNOWN CODE
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0297 UNKNOWN CODE
P0298 UNKNOWN CODE
P0299 UNKNOWN CODE
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected With Low Fuel Level
P0314 UNKNOWN CODE
P0315 UNKNOWN CODE
P0316 UNKNOWN CODE
P0317 UNKNOWN CODE
P0318 Rough Road Sensor Circuit
P0319 UNKNOWN CODE
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0345 UNKNOWN CODE
P0346 UNKNOWN CODE
P0347 UNKNOWN CODE
P0348 UNKNOWN CODE
P0349 UNKNOWN CODE
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil 1 Primary/Secondary Circuit Malfunction
P0352 Ignition Coil 2 Primary/Secondary Circuit Malfunction
P0353 Ignition Coil 3 Primary/Secondary Circuit Malfunction
P0354 Ignition Coil 4 Primary/Secondary Circuit Malfunction
P0355 Ignition Coil 5 Primary/Secondary Circuit Malfunction
P0356 Ignition Coil 6 Primary/Secondary Circuit Malfunction
P0357 Ignition Coil 7 Primary/Secondary Circuit Malfunction
P0358 Ignition Coil 8 Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0363 UNKNOWN CODE
P0364 UNKNOWN CODE
P0365 UNKNOWN CODE
P0366 UNKNOWN CODE
P0367 UNKNOWN CODE
P0368 UNKNOWN CODE
P0369 UNKNOWN CODE
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0383 UNKNOWN CODE
P0384 UNKNOWN CODE
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0409 UNKNOWN CODE
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0425 UNKNOWN CODE
P0426 UNKNOWN CODE
P0427 UNKNOWN CODE
P0428 UNKNOWN CODE
P0429 UNKNOWN CODE
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0434 UNKNOWN CODE
P0435 UNKNOWN CODE
P0436 UNKNOWN CODE
P0437 UNKNOWN CODE
P0438 UNKNOWN CODE
P0439 UNKNOWN CODE
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 EVAP Leak Monitor Small Leak Detected (***(May not be applicable for Honda / Acura)***)
P0457 UNKNOWN CODE
P0458 UNKNOWN CODE
P0459 UNKNOWN CODE
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0486 UNKNOWN CODE
P0487 UNKNOWN CODE
P0488 UNKNOWN CODE
P0489 UNKNOWN CODE
P0490 UNKNOWN CODE
P0491 UNKNOWN CODE
P0492 UNKNOWN CODE
P0493 UNKNOWN CODE
P0494 UNKNOWN CODE
P0495 UNKNOWN CODE
P0496 Evaporative Emission (EVAP) System Flow During Non-Purge
P0497 UNKNOWN CODE
P0498 UNKNOWN CODE
P0499 UNKNOWN CODE
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0508 UNKNOWN CODE
P0509 UNKNOWN CODE
P0510 Closed Throttle Position Switch Malfunction
P0511 UNKNOWN CODE
P0512 Start Switch Circuit
P0513 UNKNOWN CODE
P0514 UNKNOWN CODE
P0515 UNKNOWN CODE
P0516 UNKNOWN CODE
P0517 UNKNOWN CODE
P0518 UNKNOWN CODE
P0519 UNKNOWN CODE
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Vol***e
P0523 Engine Oil Pressure Sensor/Switch Circuit High Vol***e
P0524 UNKNOWN CODE
P0525 UNKNOWN CODE
P0526 UNKNOWN CODE
P0527 UNKNOWN CODE
P0528 UNKNOWN CODE
P0529 UNKNOWN CODE
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0535 UNKNOWN CODE
P0536 UNKNOWN CODE
P0537 UNKNOWN CODE
P0538 UNKNOWN CODE
P0539 UNKNOWN CODE
P0540 UNKNOWN CODE
P0541 UNKNOWN CODE
P0542 UNKNOWN CODE
P0543 UNKNOWN CODE
P0544 UNKNOWN CODE
P0545 UNKNOWN CODE
P0546 UNKNOWN CODE
P0547 UNKNOWN CODE
P0548 UNKNOWN CODE
P0549 UNKNOWN CODE
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0555 UNKNOWN CODE
P0556 UNKNOWN CODE
P0557 UNKNOWN CODE
P0558 UNKNOWN CODE
P0559 UNKNOWN CODE
P0560 System Vol***e Malfunction
P0561 System Vol***e Unstable
P0562 System Vol***e Low
P0563 System Vol***e High
P0564 UNKNOWN CODE
P0565 CRUISE CONTROL ON SIGNAL MALFUNCTION
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0577 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0581 UNKNOWN CODE
P0582 UNKNOWN CODE
P0583 UNKNOWN CODE
P0584 UNKNOWN CODE
P0585 UNKNOWN CODE
P0586 UNKNOWN CODE
P0587 UNKNOWN CODE
P0588 UNKNOWN CODE
P0589 UNKNOWN CODE
P0590 UNKNOWN CODE
P0591 UNKNOWN CODE
P0592 UNKNOWN CODE
P0593 UNKNOWN CODE
P0594 UNKNOWN CODE
P0595 UNKNOWN CODE
P0596 UNKNOWN CODE
P0597 UNKNOWN CODE
P0598 UNKNOWN CODE
P0599 UNKNOWN CODE
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) ErroR
P0606 PCM Processor Fault (Control Module Internal Performance)
P0607 ECU Malfunction
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0610 Control Module Vehicle Options Incorrect
P0611 UNKNOWN CODE
P0612 UNKNOWN CODE
P0613 UNKNOWN CODE
P0614 UNKNOWN CODE
P0615 Starter Relay Control Circuit
P0616 Starter Relay Control Circuit Low Vol***e
P0617 Starter Relay Control Circuit High Vol***e
P0618 UNKNOWN CODE
P0619 UNKNOWN CODE
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0623 UNKNOWN CODE
P0624 UNKNOWN CODE
P0625 Generator F-Terminal Circuit Low Vol***e
P0626 Generator F-Terminal Circuit High Vol***e
P0627 UNKNOWN CODE
P0628 Fuel Pump Relay Control Circuit Low Vol***e
P0629 Fuel Pump Relay Control Circuit High Vol***e
P0630 UNKNOWN CODE
P0631 UNKNOWN CODE
P0632 UNKNOWN CODE
P0633 UNKNOWN CODE
P0634 UNKNOWN CODE
P0635 UNKNOWN CODE
P0636 UNKNOWN CODE
P0637 UNKNOWN CODE
P0638 Throttle Actuator Control (TAC) Command Performance
P0639 UNKNOWN CODE
P0640 UNKNOWN CODE
P0641 UNKNOWN CODE
P0642 UNKNOWN CODE
P0643 UNKNOWN CODE
P0644 UNKNOWN CODE
P0645 A/C Clutch Relay Circuit (***(May not be applicable for Honda / Acura)***)
P0646 Air Conditioning (A/C) Clutch Relay Control Circuit
P0647 Air Conditioning (A/C) Clutch Relay Control Circuit
P0648 UNKNOWN CODE
P0649 UNKNOWN CODE
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0651 UNKNOWN CODE
P0652 UNKNOWN CODE
P0653 UNKNOWN CODE
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Mal***ntion
P0656 Fuel Level Output Circuit Malfunction
P0657 UNKNOWN CODE
P0658 UNKNOWN CODE
P0659 UNKNOWN CODE
P0660 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit
P0661 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit Low Vol***e
P0662 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit High Vol***e
P0663 UNKNOWN CODE
P0664 UNKNOWN CODE
P0665 UNKNOWN CODE
P0666 UNKNOWN CODE
P0667 UNKNOWN CODE
P0668 UNKNOWN CODE
P0669 UNKNOWN CODE
P0670 UNKNOWN CODE
P0671 UNKNOWN CODE
P0672 UNKNOWN CODE
P0673 UNKNOWN CODE
P0674 UNKNOWN CODE
P0675 UNKNOWN CODE
P0676 UNKNOWN CODE
P0677 UNKNOWN CODE
P0678 UNKNOWN CODE
P0679 UNKNOWN CODE
P0680 UNKNOWN CODE
P0681 UNKNOWN CODE
P0682 UNKNOWN CODE
P0683 UNKNOWN CODE
P0684 UNKNOWN CODE
P0685 UNKNOWN CODE
P0686 UNKNOWN CODE
P0687 UNKNOWN CODE
P0688 UNKNOWN CODE
P0689 UNKNOWN CODE
P0690 UNKNOWN CODE
P0691 Cooling Fan Relay Control Circuit Low Vol***e
P0692 Cooling Fan Relay Control Circuit High Vol***e
P0693 Cooling Fan Relay Control Circuit Low Vol***e
P0694 Cooling Fan Relay Control Circuit High Vol***e
P0695 UNKNOWN CODE
P0696 UNKNOWN CODE
P0697 UNKNOWN CODE
P0698 UNKNOWN CODE
P0699 UNKNOWN CODE
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
