محرك الياريس
للايمجراند 1.5
1NZ-FE
1NZ-FE
The 1NZ-FE is a 1.5 L (1497 cc) conventional Otto-cycle variant of the 1NZ-FXE with VVT-i.
It retains the same bore and stroke, but the compression ratio is lowered to 10.5:1. Output is 81,2 kW (109 hp) at 6000 rpm with 141 Nm (103 lb·ft) of torque at 4200 rpm. The redline is 6400 rpm.
Applications:
- Toyota Yaris/Echo
- Scion xA/ist
- Scion xB (1st generation)/Toyota bB (1st generation)
- Toyota Vios
- Toyota Belta
- Toyota Raum
- Toyota Porte
- Toyota Platz
- Toyota Ist
- Toyota Auris
- Toyota Fun Cargo
- Toyota Premio
- Toyota Allion
- Toyota Sienta
- WiLL VS
- Toyota Probox
- Toyota Ractis
- Toyota Corolla (Axio/Fielder, RunX, Allex)
- Geely CK (Produced under license)
- Geely MK (Produced under license)
- Great Wall C10
محرك الكورولا للجيلي ايمجراند 1.8 و ممكن طبعا لل 1.5
1ZZ-FE
1ZZ-FE
The 1ZZ-FE is a 1.8 L (1794 cc, 225 lb) version built in Buffalo, West Virginia. Its production in Cambridge, Ontario was discontinued in December 2007. Bore is 79 mm and stroke is 91.5 mm. Compression ratio is 10.0:1. Output is between 120 hp (89 kW) at 5600 rpm with 122 ft·lb (165 N·m) of torque at 4400 rpm, and 143 hp (105 kW) at 6400 rpm with 125.8 ft·lb (170.6 N·m) of torque at 4200 rpm. It uses multi-point fuel injection, has VVT-i and features fracture-split forged powder metal connecting rods, a one-piece cast camshaft, and either a cast aluminum intake manifold or a molded plastic one.[3]
A bolt-on TRD supercharger kit is available on the 2003–2004 Corolla, Matrix, and Vibe. The bolt-on TRD supercharger kit can also run on other vehicles with the non VVT-i or VVT-i versions of the 1ZZ-FE. Custom fabrications are needed for those vehicles.
Applications:
- Toyota Corolla CE/LE/S/VE, Fielder, Runx (Japan), Altis (Asia)
- Toyota Allion
- Toyota Premio
- Toyota Vista and Vista Ardeo
- WiLL VS
- Toyota Caldina
- Toyota Rav4
- Chevrolet Prizm
- Pontiac Vibe
- Toyota Celica GT
- Toyota Matrix XR
- Toyota Avensis
- Toyota Opa
- Toyota Isis
- Toyota Wish
Toyota announced a voluntary recall of 2005 to 2008 Toyota Corollas and Matrixes equipped with 1ZZ-FE engines. The issue involves the engine control module, and includes the potential for it to develop a crack on the module's circuit board, which can result in the car not starting, the transmission shifting harshly, or the engine stalling. Additionally, Pontiac announced a voluntary recall of Pontiac Vibes from years 2005 to 2008 for the same issue.
1ZZ-FED
The 1ZZ-FED is similar to the 1ZZ-FE but is built in Shimoyama, Japan. Output is 140 hp (104 kW) at 6400 rpm with 126 ft·lb (171 N·m) of torque at 4200 rpm. It uses MFI fuel injection, VVT-i and light weight, cast rods.
Applications:
- Toyota Corolla
- Toyota Celica GT
- Toyota MR2 Spyder
- Toyota Wish 1.8
- WiLL VS 1.8
3ZZ-FE
The 3ZZ-FE is a 1.6 L (1598 cc) incarnation built in Japan. It is found in the Asian Toyota Corolla Altis which is available in countries such as Singapore, Malaysia, Philippines, Thailand and Taiwan and in the Toyota Corolla sedan sold in Sri Lanka. In South Africa the motor can be found in the RunX 160 and Corolla 160. The entire exterior design and chassis is the same as the American Corolla. Bore is 79.0 mm and the stroke is 81.5 mm. Max. output is 109 hp (81 kW) @ 6000 rpm. Max. torque is 110 lb·ft (150 Nm) @ 3800 rpm. Features SMP pistons v/s Toyota made in 1ZZ-FE engine. The preferred engine oil is 5W30 API grade SL/SM.
Applications:
- Toyota Corolla (Europe & Middle East, 109 hp)
- Toyota Corolla Altis 1.6E (Asian, 110 hp)
- Toyota Corolla RunX 160 (South African, 81 kW @ 6000 and 146 Nm @ 4400)
- Toyota Corolla XLi (Brazil, 110 hp)
- Toyota Avensis (Europe, 109 hp)
4ZZ-FE
The 4ZZ-FE is a 1.4 L (1398 cc) version. Bore is 79.0 mm and stroke is 71.3 mm. Output is 95 hp (71 kW) at 6000 rpm with 96 ft·lb (130 N·m) of torque at 4400 rpm.
Applications:
- Toyota Corolla
- Toyota Auris
- Toyota RunX 140
