very good comparison and really a good job, since i'm an opel insignia owner i can tell that all things about insignia are almost true. I just would like to correct some of the data on the topline model as follow:
1- أوبل: الخلوص الأرضي ممتاز، ولكن مع التحميل غير معروف (its not making any sense, its good in all ways)
2- regarding the gear box (أوبل: ثقيل نوعًا ما) its not true, i cant see how its soft and hard in the same time!!!
3- نظام مقياس ضغط الإطار - (Tire pressure monitor system (TPMS)
(Yes | No | No (no its not true the insignia has the TPMS
4- توزيع إلكتروني لقوة المكابح - Electronic Brakeforce Distribution [EBD]
(Yes | No | Yes (no its not true the insignia has EBD
5- فتح الأبواب بلمس المقابض - Touch door handle to open
(Yes | No | Yes (no its not true the insignia has this option
6- كشافات تتحرك مع انعطاف السيارة - Active headlights
(Yes | No | No (no its not true the insignia has this option
7- أوبل: يحتاج المصباح إلى حوالي 10 ثوان حتى يصل إلى درجة التوهج القصوى (thats a normal for any xenon light)
8- مقبس كهرباء 12 فولت أمامي - Front 12V socket
مقبس كهرباء 12 فولت في المسند الأوسط - 12V socket in the center armrest
9- بطانة الأبواب من الجلد - Leather door trim
Note: could you please clarify what you mentioned about (الوكيل قد يتحايل ويسلم سيارة من فئة أقل) cause its not making any sense?!
I think the following numbers are not accurate, could you please clarify from where you got these numbers?
معدل التناقص السنوي في السعر [%] | Depreciation [%]
20.5 | 23.8 | 26
الانتشار في السوق [%] | Availability [%]
73 | 23 | 4
And finally big thanks to you, with my regards
