كلامك ونصائحك على العين والراس ياهندسة:tumb::tumb:
مية نيسان مواصفاتها مكتوبة بطريقة مختلفة ومافهمتهاش
سائل التبريدحاجيبه بنفسي وحاشرف على عملية الغسيل وتركيب المبرد الجديد
رابط
دى سوائل تبريد لسيارات فولكس من شركه اسمها OPie
http://www.opieoils.co.uk/c-1551-vw-...ntifreeze.aspx
يتضح الاتى :
- G11 يمكن خلطه مع G12+ او G12++ فقط
- G11 لا يمكن خلطه مع g12 او g13
- G12 يمكن خلطه مع G12+ او G12++ فقط
- G13 يمكن خلطه مع G12++ فقط
- G13 لا يمكن خلطه مع G12+ او G12 او G11
VW G11 (TL 774 C) Specification Antifreeze
Looking for G11 (TL 774 C) spec antifreeze for your Volkswagen car, find our range right here
Opie Oils stocks a great range of Coolant and Antifreeze that meet specific VW specification G11 (VW TL774 C). Volkswagen models manufactured before 1997 used G11 coolant, typically (but not always!) coloured blue. G11 coolant is equivalent to the VW blue coolant part numbers G011000 and VW-W043611. G11 VW coolant should not be mixed with the later G12 coolant but *can* be mixed with the G12+ and G12++ coolant that supercedes both G11 and G12. G11 coolant is not a longlife coolant and should be replaced every 12 months. If you are unsure as to what kind of coolant you have, the safest option is to drain, flush and replace with the latest, longlife G12++ coolant.
VW G12 & G12+ (TL774 D / F) Specification Antifreeze
Looking for G12 & G12+ (TL774 D / F) spec antifreeze for your Volkswagen car, find our range right here
Opie Oils stocks a great range of Coolant and Antifreeze that meet specific VW specification G12 / G12+ (VW TL774 D / F).
Volkswagen G12 and G12+ coolants are longlife coolants; replace every 3 years. G12 cannot be mixed with the earlier G11 coolant but can be mixed with G12+ and G12++ coolants. G12+ coolant can be mixed with both G11 and G12++.
VW G12 & G12+ Antifreeze (TL 774 D / F)
VW G12++ Antifreeze (TL 774 G)
VW G12++ Antifreeze (TL 774 G) Specification Antifreeze
Looking for G12++ Antifreeze (TL 774 G) spec antifreeze for your Volkswagen car, find our range right here
Opie Oils stocks a great range of Coolant and Antifreeze that meet specific VW specification G12++ (VW TL774 G).
Volkswagen G12++ coolant is a longlife coolant; replace every 3 - 5 years. It can be mixed with everything that VW / Audi have used as a factory fill coolant, so this is a safe option if you don't know what's in your cooling system already.
VW G13 Antifreeze (TL 774 J)
VW G13 Antifreeze (TL 774 J) Specification Antifreeze
Looking for G13 Antifreeze (TL 774 J) spec antifreeze for your Volkswagen car, find our range right here
Volkswagen G13 coolant is a longlife coolant; replace every 3 - 5 years. It can be mixed with all coolants meeting the G12++ (VW TL 774 G) specification. Volkswagen G13 coolant is a more environmental friendly coolant.
انا قلت لك كده فى الردود .. ان شركات السيارات عاده موش بتحط المواصفه و بتعمل سوائل تبريدها بنفسها و بتسميها باسم الشركه و معاها رقم كودى
انا كنت فاكر انك حتسأل البائع او جد معرفتك لانك قلت احضار المواصفه سهل .. لازم تسأل جد من نيسان ( زى ما عملت مع بتوع ميه التبريد لعربيتك ) و تحاول تفهم المحموعه
و ان لم تصل لنتيجه .. يجب وضع مواصفه نيسان اللى على العلبه ( كامله ) او تصور العلبه من الناحيتين و نشوف على النت
و زى ما ظهر فى ردى الاخير ..
ال G13 اللى انت كنت ناوى تستعمله اتضح انه لا يستعمل الا مع G12++ فقط ..
يعنى حتى لا يصلح مع G12 او g12+ ده طبعا بالاضافه الى انه لا يصلح مع G11
بمعنى اصح كنت ستتخذ قرار خاطئ للمره الثانيه يبوظ موتورك للمره الثانيه !! ؟؟
يجب وضع مواصفه نيسان اللى على العلبه ( كامله ) او تصور العلبه من الناحيتين و نشوف على النت .. لازم تحاول تسأل موزعين معتمدين نيسات لغايه ما تغرف .. لانى اعتقد البحث على النت موش حيجيب نتيجه بنسبه كبيره لان دى سوائل خاصه باستعمال محدد
يتضح ان g12++ يمكن خلطه مع جميع سوائل التبريد .. سواء السابقه لظهوره مثل g11 او g12 او g12+ .. او اللاحقه بعده مثل g13اقتباس:
يتضح الاتى :
- g11 يمكن خلطه مع g12+ او g12++ فقط
- g11 لا يمكن خلطه مع g12 او g13
- g12 يمكن خلطه مع g12+ او g12++ فقط
- g13 يمكن خلطه مع g12++ فقط
- g13 لا يمكن خلطه مع g12+ او g12 او g11
الكلام ده لتركيبه ميه فولكس .. اما خلطه على ميه نيسان ؟؟ .. معنديش اى فكره
لا .. الزيت الاماراتى موش محقق المواصفه المطلوبه لفولكس
هو عنده 3 موافقات .. منهم 2 للديزل غير مناسبين .. و الثالثه للبنزين و هى 502 و دى موش مناسبه لعربيتك ( المطلوب لعربيتك 503.1 )
ده اقتباس ردى
و ده رد المهندس بوريو بخصوص المواصفه ان مواصفه 502 لا تستعملهااقتباس:
الزيوت التى تم استعمالها1- الزيت الاماراتى
- انت قلت انك استعملت لزوجه 0W30 .. دى المفروض موجوده فقط فى اعلى زيت عندهم ( الذهبى )
- موافقات الزيت الاماراتى ليس بها موافقه الزيت الخاص بيك و هى VW 503.01 .. الموافقات الموجوده هى 3 موافقات بارقام اخرى لا تناسب سيارتك
- لزوجه الزيت الاماراتى لا تناسب سيارتك حسب الكتالوج
اقتباس:
وويمنع تماما وضع أي زيت بمستوى أقل في مواصفات فولزفاجن (زي VW 502.00 أو VW 501.00 أو VW 500.00)
وكيل فولكس بتاع ابوظبي رد على ووصاني بنفس الانتي فريز الموجود في الكتالوج ولما سألته القاه وين قال لي عند الموزعين المعتمدين وقال لي حط تلاتة لتر من السائل مع 3 لتر ماء مقطر وبالنسبة للزيت قال لي استخدم موبيل 1 0w40 !
انا رحت للموزع المعتمد لقيت مبردات بورش وبي ام وواحد الماني ( تقريبا هو الاقرب لفولكس ) لكن مالقيتش مبرد فولكسواجن وقال لي حاجيبه لك بطلبية خاصة , قال لي جماعة بورش وبي ام دبليو مابستخدموش الا حاجات الوكالة اما جماعة فولكس فبمشوا نفسهم باي حاجة ههههههههههه عشان كدة لوجبته بخسر !
ملف مرفق 15531ملف مرفق 15534ملف مرفق 15530
ملف مرفق 15532
عموما في فتي حاصل ههههههههههههههههههههه .. شوف اهي دي فولكس امريكا كاتبة مواصفة مختلفة شوية للمية A8F وليس A8D !
PURPLE مش RED زي الكاتلوج او حتى PINK زي جماعتنا ( معليش الصورة مش واضحة لكن نسخت لك جزئية المية من البي دي اف )
http://www.mediafire.com/convkey/d95...k61htad0zg.jpg
¤COOLING SYSTEM: Use only phosphate free coolant G 012 A8F A4, PURPLE COLORED. DO NOT INTERCHANGE OR MIX older G 11(ZVW 237 105), GREEN
COLORED. This can result in serious damage to the engine. However, it may be mixed with ZVW 237 G12, PINK COLORED. Frost protection is required down
to approximately -25_C (-13_F). In countries with arctic climates, frost protection is required down to approximately --35_C (--31_F). The anti-freeze ratio must
be a minimum of 40%, as otherwise frost protection is reduced. The recommended mixture ratio is 50:50. If greater frost protection is required (very cold climates),
the amount of G 012 A8F A4 can be increased, but only up to 60%. This provides frost protection to approx. -40_C (--40_F). Do not reduce the coolant concentration
by adding water, even in warmer seasons and in warmer countries, as cooling effectiveness will be reduced.
تحذير شديد
لابد من معرفه نوع ميه نيسان .. لان ده حيحدد ميه التبريد المسموحه ليك .. او ازاى حتتصرف لو حبيت تستعمل ميه الكتالوج
لا تطلب اجضار ميه الكتالوج بتاعك قبل ذلك
انتظر رد نهائى منى اليوم قبل ما تتصرف
اسال وكيل نيسان عن المجموعه .. و ضع رقم المنتج هنا بتاع ميه نيسان ( برغم انه مستبعد الاقى مواصفته على الانترنت ) .. و الصور ان امكن
ميه G11 هى مجموعه IAT
ميه g12 هى مجموعه OAT
و كمان تقول لبتوع ابو ظبى انك حطيت ميه نيسان موش عارف مجموعتها .. .. لانهم فى الحاله دى ردهم سيختلف طبعا .. و تقول لهم على رقم ميه نيسان و لونها ( يمكن حيعرفوا مواصفتها .. احتمال كبير )
و حيطلبوا منك فلش كامل قبل ما تستعمل الميه الاصليه بتاعه الكتالوج .. ( و ده بيحصل زى ما اوضحت لك عند فك طلمبه الميه وقت تغيير سير التقسيمه ) و ده موش حاجه بسيطه فى التكلفه
لابد من معرفه نوع ميه نيسان لان ده حيسهل اختيار الحلول و يوفر عليك تكلفه اضافيه
