اقتباس:
المشاركة الأصلية كتبت بواسطة عمرعبدالله
عموما في فتي حاصل ههههههههههههههههههههه .. شوف اهي دي فولكس امريكا كاتبة مواصفة مختلفة شوية للمية A8F وليس A8D
¤COOLING SYSTEM: Use only phosphate free coolant G 012 A8F A4, PURPLE COLORED. DO NOT INTERCHANGE OR MIX older G 11(ZVW 237 105), GREEN
COLORED. This can result in serious damage to the engine. However, it may be mixed with ZVW 237 G12, PINK COLORED. Frost protection is required down
to approximately -25_C (-13_F). In countries with arctic climates, frost protection is required down to approximately --35_C (--31_F). The anti-freeze ratio must
be a minimum of 40%, as otherwise frost protection is reduced. The recommended mixture ratio is 50:50. If greater frost protection is required (very cold climates),
the amount of G 012 A8F A4 can be increased, but only up to 60%. This provides frost protection to approx. -40_C (--40_F). Do not reduce the coolant concentration
by adding water, even in warmer seasons and in warmer countries, as cooling effectiveness will be reduced.
مفيش فتاوى .. الكلام متناسق فى معظمه الا جزئيه واجده فقط ( و ممكن يكون ليها تفسير كمان )
ال G12 A8D يساوى TL774 D يساوى GL12 العادى ( اقدم نوع )
ال G12 A8F يساوى TL774 F يساوى GL12+
فى امريكا تم استبدال ال GL12 العادى ( اقدم نوع ) بنوع احدث كبديل و هو G12+ ( اللى هو G12 A8F ) .. علشان كده الكتالوج ذكر G12 A8F
و ده اقتباس من ردى السايق فى نفس الصفحه لتحديد كود كل سائل تبريد و توافقه
VW G12 & G12+ (TL774 D / F) Specification Antifreeze
Looking for G12 & G12+ (TL774 D / F) spec antifreeze for your Volkswagen car, find our range right here
Opie Oils stocks a great range of Coolant and Antifreeze that meet specific VW specification G12 / G12+ (VW TL774 D / F).
Volkswagen G12 and G12+ coolants are longlife coolants; replace every 3 years. G12 cannot be mixed with the earlier G11 coolant but can be mixed with G12+ and G12++ coolants. G12+ coolant can be mixed with both G11 and G12++.
ملخص المكتوب بالانجليزى فى الكتالوج الامريكى
1- استعمل سائل تبريد G12+
2- لا تخلط G11 مع سائل تبريد G12+ لانه سيتسبب فى اضرار شديده للمحرك
3- يمكنك خلط G12 مع سائل تبريد G12+
4- نسبه الخلط 50% .. و ممنوع نهائيا ان تتعدى 60%
اقتباس:
PURPLE مش RED زي الكاتلوج او حتى PINK زي جماعتنا ( معليش الصورة مش واضحة لكن نسخت لك جزئية المية من البي دي اف )
بالنسبه للون :
1- كما اوضحت سابقا .. اللون لا يعنى شيئ مطلقا .. و مفيش اى مواصفه قياسيه عالميه تلزم الشركات بالوان معينه
2- اللون هو مجرد صبغه تضاف الى سائل التبريد وليس لها اى تأثير على تركيبه السائل
3- اختيار الالوان عاده بيتم بالتنسيق بين صانعى السيارات المعروفين .. كل صانع بيختار مجموعه الوان خاصه به لعدم حدوث لبس اثناء شراء سائل التبريد
بالنسبه للون فى الكتالوج الامريكى
ال G12 A8D يساوى TL774 D يساوى GL12 العادى ( اقدم نوع ) .. ده لونه PINK فى امريكا
ال G12 A8F يساوى TL774 F يساوى GL12+ .. ده لونه PURPLE فى امريكا .. و ده هو اللون الطبيعى لفولكس للسائل ده
اما سبب اختيار اللون ال Pink فى امريكا ( حسب ما اظن ) .. اعتقد ده بسبب ان اول سائل تبريد فى امريكا OAT كان لونه Orange او Pink ( اعتقد كان اسمه Dex Cool ) .. فبالتالى هو اختار لون مألوف للناس لفهم نوعيه سائل التبريد بتاع فولكس .. لان فيه ناس كتير هناك بتميز السوائل دى باللون
و كمان فيه شركه سوائل تبريد مشهوره هناك .. بتعمل ال G12 العادى باللون ال Pink
الملحوظه الوحيده هنا
- ان الكتالوج منع خلط G12+ مع G11 .. و دى معلومه انا قرأتها اكثر من مره سابقا ( و برضه قرأت رأى عكسها .. انه ممكن الخلط )
- سائل تبريد شركه OPie المخصص لفولكس .. سمحت بخلط G12+ مع G11
- فهل المنع ده فى سوائل فولكس فقط ؟؟ .. ام بصفه عامه لكل ال G12+ لجميع الماركات الاخرى ؟؟ .. و هل مثلا تركيبه سائل التبريد لشركخ Opie معموله بحيث تسمح بكده مثلا ؟؟ محتاجه بحث
علشان كده قلت لك ان فيه كلام متضارب كتير بخصوص G12+ سواء لميه فولكس او غيرها .. و ان الامن هو G12++ ( لو فيه احتياج لتوافق مع G11 لسبب ما ) .. ال G12++ مفيش عليه خلاف ( بنسبه كبيره )
