الله ينور موضوع مفيد
رقم العضوية : 160979
الاقامة : Maadi
السيارة: هويونداى i10 2013
السيارة[2]: نيسان صنى 2015
دراجة بخارية: Honda Shadow 400
[justify]مقتبس من: Eric-the-car-guy2WD: 2 Wheel Drive4WD: 4 Wheel Drive4WS: 4 Wheel Steering2V: 2 Valve (cylinder head)4V: 4 Valve (cylinder head)AAT: Ambient Air TemperatureABS: Antilock Brake SystemAC: Air ConditioningACC: Adaptive Cruise Control also Automatic Climate ControlA/F sensor: Air Fuel SensorAFR: Air Fuel Ratioalt: AlternatorARS: Automatic Restraint SystemARC: Automatic Ride ControlA/T: Automatic TransmissionATC: Automatic Temperature ControlATF: Automatic Transmission FluidAWD: All Wheel DriveAYC: Active Yaw ControlBaro: Barometric pressure. Usually a sensor.batt: BatteryBCM: Body Control ModuleBHP: Brake HorsepowerBTDC: Before Top Dead CenterCAA: Clean Air ActCAFE: Corporate Average Fuel Economy (USA)CEL: Check Engine LightCFI: Central Fuel InjectionCFM: Cubic Feet Per MinuteCG: Center of GravityCID: Cubic Inch DisplacementCKP Crankshaft PositionCL: Closed Loopcmd: CommandCMP: Camshaft PositionCNG: Compressed Natural GasCO: Carbon Monoxidecomm: CommunicationCO2: Carbon DioxideCOP: Coil On PlugCPU: Central Processing UnitCTS: Coolant Temperature SensorCV: Constant VelocityCVT: Continuously Variable TransmissiondB: DecibelsDC: Direct CurrentDFI: Direct Fuel Injectiondiff: DifferentialDIS: Direct Ignition Systemdist: DistributorDLC: Data Link ConnectorDMM: Digital MultiMeterDOHC: Dual Overhead CamDPFE: Differential Pressure Feedback (Ford EGR)DRL: Daytime Running LightsDTC: Diagnostic Trouble CodeDVOM: Digital Volt Ohm MeterE4OD: Electronic 4-speed Overdrive transmissionE10: Ethanol 10%E85: Ethanol 85%EAS: Electronically Assisted SteeringECBM: Electronic Brake Control ModuleECM: Engine Control ModuleECM: Electronic Control ModuleECS: Emission Control SystemECT: Engine Coolant TemperatureECU: Electronic Control ModuleEDR: Even Data RecorderEEC: Electronic Engine ControlEPROM: Erasable Programable Read Only MemoryEFE: Early Fuel EvaporationEFI: Electronic Fuel InjectionEGR: Exhaust Gas RecirculationELC: Electronic Level ControlEPA: Environment Protection AgencyEPC: Electronic Pressure ControlESC: Electronic Spark ControlELD: Electronic Load DetectionESP: Electronic Stability ProgramETC: Electronic Temperature ControlETS: Electronic Traction SystemEV: Electric VehicleEVAP: Evaporative EmissionsFBC: Feedback CarburetorFF: Flex FuelFFV: Flexible Fuel VehicleFM: Frequency ModulatedFPS: Fast Pass Standardfreq: FrequencyFT: Fuel TrimFTP: Fuel Tank PressureFTPT: Fuel Tank Pressure TransducerGAWR: Gross Axle Weight RatingGND: GroundGPCM: Glow Plug Control ModuleGPS: Global Positioning SystemGVW: Gross Vehicle WeightGVWR: Gross Vehicle Weight RatingH2O: WaterHC: HydrocarbonsHD: Heavy DutyHDR: Hight Data RateHEGO: Heated Exhaust Gas Oxygen sensor (Now HO2S)HEV: Hybrid Electric VehicleHg: MercuryHID: High Intensity DischargeHO: High OutputHO2S: Heated Oxygen Sensorhp: HorsepowerHVAC: Heating Ventilation and Air ConditioningHz: HertzIA: Intake AirIAC: Idle Air ControlIAT: Intake Air TemperatureiATN: INternational Automotive Technicians NetworkIC: Integrated CircuitIC: Ignition ControlID: IdentificationID: Inside DiameterIDI: Integrated Direct IgnitionIDM: Ignition Diagnostic ModuleIDM: Injector Driver ModuleIDS: Integrated Diagnostic SoftwareIGN: IgnitionI/M: Inspection MaintenanceIMA: Integrated Motor AssistINJ: Injectorint: InteriorI/O: In/OutIAC: Idle Air Controli-VTEC: Intelligent Variable Valve Timing Electronic ControlKAM: Keep Alive MemoryKAPWR: Keep Alive Memory Powerkg: Kilogramkg/h: Kilograms per Hourkm: Kilometerkm/h: Kilometer per Hourkm/l: Kilometers per LiterKOEO: Key Off Engine OnKOER: Key On Engine RunningkPa: KilopascalKS: Knock Sensorkv: KilovoltsL: LiterL4: Inlie 4 cylinder engineLCD: Liquid Crystal DisplayLCM: Lighting Control ModuleLDR: Low Data RateLED: Light Emitting DiodeLEP: Light Emitting Polymer (glows in the dark)LEV: Low Emissions VehicleLm: LumensLNG: Liquid Natural GasLPG: Liquid Petroleum GasLPM: Liters Per MinuteLPS: Low Pressure SensorLSD: Limited Slip DifferentialLSUV: Luxury Sport Utility VehicleLT: Long Term (Fuel Trim)LTPWS: Low Tire Pressure Warning SystemMAF: Mass Airflow SensorMAP: Manifold Absolute PressureMAT: Manifold Air TemperatureMC: Mixture ControlMCU: Microprosessor Control UnitMFI: Multiport Fuel InjectionMGMT: ManagementMIL: Malfunction Indicator Lampmm: MillimeterMSRP: Manufacturer Suggested Retail PriceM/T: Manual TransmissionmV: MilivoltMV: MegavoltNC: Normally ClosedNCAP: New Car Assessment ProgramNAVI: NavigationNEG: NegativeNEU: NeutralNG: Natural GasNGV: Natural Gas VehicleNO: Normally OpenNOx: Nitrogen OxidesNPF: No Problem FoundNPTC: National Pipe Thread CoarseNPTF National Pipe Thread FineNV: Night VisionO2: OxygenO2S: Oxygen SensorOBD: On Board DiagnosticsOBDII: On Board Diagnostics generation 2OBDIII: On Board Diagnostics generation 3OCC: Output Circuit CheckOCR: Oil Control RingOD: Outside DiameterOD: OverDriveODO: OdometerOE: Original EquipmentOEM: Original Equipment ManufacturerOHC: Overhead CamOL: Open LoopPASS: PassengerPB: Power BrakesPC: Pressure ControlPCI: Programable Controller InterfacePCM: Powertrain Control ModulePFE: Pressure Feedback EGRPGMFI: Programable Multiport Fuel InjectionPID: Parameter IdentificationPIM: Power Inverter ModulePIP: Profile Ignition Pickup (also CKP Crank Position)POS: PositivePOT: Potentiometerppm: Parts Per MillionPRNDL: Park Reverse Neutral Drive LowPROM: Programable Read Only MemoryPS: Power SteeringPSA: Pressure Switch Assemblypsgr: Passengerpsi: Pounds Per Square Inchpsi a: Ponds Per Square Inch Absolutepsig: Pounds Per Square Inch GaugePSP: Power Steering PressurePTC: Pending Trouble CodePTC: Positive Temperature CoefficientPTO: Power Take OffPWM: Pulse Width ModulationPWR: PowerRAM: Random Access Memoryrec: ReceiveREDOX: Reduction Oxidation Catalytic ConverterREF: ReferenceRFI: Radio Frequency InterferenceRFID: Radio Frequency IdentificationRly: RelayRM: Relay ModuleR&R: Remove and ReplaceRSC: Roll Stability ControlRTV: Room Temperature VulcanizingRV: Recreational VehicleRWD: Rear Wheel DriveSAE: Society of Automotive EngineersSDL: Serial Data LInkSEFI: Sequential Electronic Fuel InjectionSEMA: Special Equipment Market AssociationSES: Service Engine SoonSFI: Sequential Fuel InjectionSHO: Super Hight OutputSIR: Supplemental Inflatable RestraintSNSR: SensorSO2: Sulphur DioxideSOC: State of Changesol: SolenoidS/P: Series ParallelSPD: SpeedSRS: Supplemental Restraint SystemSSV: Shift Solenoid ValveST: Short Term (fuel trim)stdby: StandbySUV: Sport Utility Vehiclesw: SwitchSWPS: Steering Wheel Position SensorTACH: TachometerTB: Throttle BodyTBI: Throttle Body InjectionTC: Transmission ControlTCC: Torque Converter ClutchTCM: Transmission Control ModuleTCS: Traction Control SystemTCU: Transmission Control UnitTDC: Top Dead CenterTEMP: TemperatureTFI: Thick Film Integrated (Ford Ignition)TFT: Transmission Fluid Temperaturetorq: TorqueTP: Throttle PositionTPI: Tuned Port InjectionTPMS: Tire Pressure Monitoring SystemTPS: Throttle Position Sensortrans: TransmissionTSB: Technical Service BulletinTSS: Transmission Speed SensorTV: Throttle ValveTVS: Thermal Vacuum SwitchTWC: Three Way CatalystU/H: Under HoodULEV: Ultra Low Emissions VehicleULSD: Ultra Low Sulphur Dieselunlk: UnlockV: VoltsVAC: VacuumVAF: Vane Air FlowVAPS: Variable Assist Power SteeringVB: Valve BodyVCM: Vehicle Communication ModuleVCT: Variable Camshaft TimingVCDS: Vehicle Dynamics Control SystemVDR: Vehicle Data Recorderveh: Vehiclevel: Velocityver: Versionvert: VerticalVIN: Vehicle Identification NumberVSS: Vehicle Speed SensorVSV: Vacuum Solenoid ValveVTEC: Variable Timing and Electronic ControlVVT-i: Variable Valve Timing with IntelligenceVVTL-i: Variable Valve Timing and Lift with Intelligencew/: Withw/o: WithoutWOT: Wide Open ThrottleWSS: Wheel Speed SensorX-valve: Expansion ValveZEV: Zero Emissions Vehicle[/justify]
رقم العضوية : 18045
الاقامة : sh
السيارة: no
السيارة[2]: verna
رقم العضوية : 175126
الاقامة : دمياط
السيارة: Accent 1.3
السيارة[2]: Lancer Puma
تسلم ايديك موضوع مميز ومفيد
اللهم أشفى أمى وأشفى مرضى المسلمين
