changing the cover should help
when you use regular water it vaporizes and the steam could escape from any weak point at the circuit
the radiator cap is the first to blame when this happens
use coolant fluid ( i use 40% concentration green fluid ) it helped keeping the temp under control
or you can get the 20l.e. coolant can and add it to regular water
and just to be sure, let some specialist take a look at your car and make sure there`s no leaks anywhere
LinkBack URL
About LinkBacks
رد مع اقتباس
