دة كلام من توكيل تويوتا فى اليونان و بيعرف طريقة عمل السيارة و انا ترجمتها من جوجل و للناس اللى بيقولو ان السيارة فى اوروبا و ما فيهاش عيب لازم يدخلوا على الويب دة و يعرفوا ان عندهم نفس المشاكل حتى الان و لا حتى القطعة السحرية اياها حلت المشكلة و هما لسة بيعانو من المشكلة و انا على اتصال معاهم و عاملين منتدى ام ام تى زبنا و اسيبكم مع الكلام الكتير تحت و شكرا
وليد رفاعى
0101129899
Corolla Verso Mmt Problems - Toyota Owners Club - Toyota Forum
Let me start by explaining the transmission arrangement. The gearbox is an ordinary 5 speed manual box with a manual friction clutch. The differences come with the control system. The gear selection process is taken care of by two electric motors, one for across the gate and one for engagement. Both motors have very sensitive sensors attached that measure their position extremely accurately. Down to one hundreth of a millimetre. The clutch is controlled by another electric motor, again fitted with a very sensitive sensor with the same accuracy as the selector motors. The engine speed, road speed and throttle position are all fed into the transmission control unit where the decisions are made as to what gear to be in and how to control the clutch. The control unit will do it's best to be in the right gear at the right time, but don't forget there is no input from the road. It can't know that there is a hill coming up or that you are going to stop quickly etc. Regarding the driving technique, you need to throw away all you have leaned from manual boxes and likewise for auto boxes. This box has a rule book of its own. From the road tests that I've done, I've found that flooring the throttle in E mode produces a reasonable journey, if a little jerky. This is no good for town work though. You can go the route of holding a steady throttle, and allowing the transmission to do the rest- I've found that to be very uncomfortable. As the engine power is reduced ready for a gear change, your body is thrown forwards, matched by a correspoding lurch backwards as the power comes back in. The best technique I've found is to press the throttle to take of from rest, just a little bit more than you would do normally. Then, when you are ready for a gear change, lift off the throttle and let it change. After the change feed the power back in and you get a smooth change. Do this for all gear changes up the box (1-2, 2-3, 3-4, etc) Coming down the box, say for a junction, let the box decide what gear to be in and then ease on the throttle to take off/increase speed. Try to avoid punching the throttle on as this will be interpreted by the system as a demand for more power and a change down. The engine will then "flare" (revs will rise, but no drive), and the box selects neutral to avoid damage. When the control unit decides it is safe to do so, it will engage a gear and let you drive. During hill climbing, your road speed will drop as the engine can't maintain your speed in the current gear. Keep increasing the throttle opening until the box changes down a gear. A specific complaint is when climbing a long hill the box keeps changing from E2 to E3 and back again. The reason for this is because in E3 there is not enough power to maintain your speed, so you slow down, the box changes down to E2, now there is enough power to accelerate you up to the point where you can change to E3, and the cycle starts again. To avoid this annoying cycle, just pop into manual mode and stay in E2 until you reach the top of the hill, then back into E mode.
Moving on to manouvering, especially backwards, try to get the clutch engaged fully if you can. If not, don't worry, there will be a bit of a smell, like burning or hot rubber. This is horrible, but quite normal. Since clutch friction plates no longer contain asbestos, for safety reasons, the alternative friction material produces this horrible smell in use. The smell will disperse quickly. If you are travelling up hill, forwards or backwards, so slowly that the clutch is slipping all the time, you will cause smell and possibly smoke and probably damage. There is no temperature sensor in the clutch, so the system works out the theoretical temperature from the work that it is doing. If the clutch overheat warning sounds then stop and let things cool before proceeding.
Reading Jane's post about hill descent, when the control unit sees throttle backed off, foot on the brakes and slowing down, it will change down for you to produce engine brake. Once your speed is under control try easing off the brake and let the engine do the work of slowing you down. When you get to the bottom of the hill, ease on the throttle rather than punch it on, as the system will see that as a demand for more power and change down.
With regard to the driving technique, I'm not being critical of anybody who has trouble with MMT transmissions, just trying to re-educate them. I once had to deal with an irate lady customer who had trouble with her MMT. Usual story- clutch slip, smoke and smell and loss of drive. When I suggested that she would have to modify her driving technique, she went ballistic and told me that she had been driving 50 years and didn't need to change now. She wouldn't listen and went away very unhappy.
I'm very sorry to hear of all the problems you have been having. I hope that this huge post may have helped you understand how your transmission works and how to get the best out of it.
BTW regarding modern fully automatic gearboxes:- when the engine speed and road speed are matched, the torque converter is locked up with a special clutch and there is no loss of power. This clutch unlocks as soon as the system detects a drop in road speed.
If you have a specific problem relating to MMT transmission and its operation, please post here and I will do my best to provide an explanation/answer.
Cheers Ray
[IMG]file:///C:/DOCUME%7E1/Walid/LOCALS%7E1/Temp/msohtml1/01/clip_image001.gif[/IMG]Show romanization
اسمحوا لي أن أبدأ بشرح ترتيب انتقال. علبة التروس هو عادي 5 مربع سرعة الخط مع الخط الفاصل الاحتكاك. الاختلافات تأتي مع نظام التحكم. والعتاد عملية الاختيار هو العناية من قبل اثنين من المحركات الكهربائية ، واحد لعبر بوابة واحدة للمشاركة. كلا المحركات وأجهزة استشعار حساسة للغاية المرفقة التي تقيس مواقفها بدقة متناهية. نزولا الى واحد hundreth من الميليمتر. مخلب يتم التحكم بمحرك كهربائي من جانب آخر ، ومرة أخرى مزودة جهاز استشعار حساسة للغاية مع دقة نفس المحركات محدد. سرعة المحرك ، والسرعة على الطرق وخنق الموقف كلها تغذي لإرسال وحدة التحكم حيث يتم اتخاذ القرارات فيما يتعلق بما والعتاد ليكون في وكيفية السيطرة على مخلب. وحدة التحكم وسوف نفعل ذلك من الأفضل أن يكون في الحق والعتاد في الوقت المناسب ، ولكن لا ننسى ان هناك أي مدخلات من الطريق. فإنه لا يمكن أن نعرف أن هناك تلة القادمة أو التي كنت تسير بسرعة لوقف الخ وفيما يتعلق أسلوب القيادة ، وتحتاج إلى رمي بعيدا كل لديك مال من مربعات اليدوية وبالمثل لصناديق السيارات. في هذه الخانة لديه كتاب القواعد من تلقاء نفسها. عن طريق الاختبارات التي قمت بها ، لقد وجدت أن الأرضيات دواسة الوقود في وضع البريد تنتج رحلة معقولة ، إذا كان متشنج قليلا. هذا ليس جيدا للعمل على الرغم من البلدة. يمكنك الذهاب في الطريق لعقد خنق مطرد ، والسماح للانتقال الى تفعل بقية ، لقد وجدت أن ذلك غير مريح للغاية. كما يتم تخفيض قوة المحرك جاهز للتغيير والعتاد ، ويتم طرح جسمك إلى الأمام ، يقابله correspoding تمايل الى الوراء وعودة التيار الكهربائي فيها وتقنية أفضل وجدتها هي الضغط على دواسة الوقود لاتخاذ لمن الراحة ، فقط أكثر قليلا مما كنت تفعل في العادة. ثم ، عندما تكون مستعدا لتغيير والعتاد ، ويقلع عن دواسة الوقود والسماح لها تغيير. بعد التغيير تغذية السلطة مرة أخرى في وتحصل على التغيير على نحو سلس. تفعل ذلك بالنسبة لجميع التغييرات والعتاد حتى مربع (1-2 ، 2-3 ، 3-4 ، الخ) يطرح باستمرار مربع ، ويقول لمفترق طرق ، دعونا نقرر ما مربع والعتاد ليكون في سهولة ومن ثم على دواسة الوقود ل تقلع / زيادة السرعة. في محاولة لتجنب خنق اللكم على هذا النحو سوف يفسر من قبل النظام والطلب من أجل المزيد من السلطة وتغيير باستمرار. المحرك سوف ثم "مضيئة" (الدورات سوف ترتفع ، ولكن لا محرك الأقراص) ، ومربع يختار محايدة لتجنب الضرر. وحدة التحكم عندما تقرر أنها آمنة للقيام بذلك ، وسوف تعمل والعتاد وتمكنك من محرك الأقراص. أثناء تسلق المرتفعات ، سيتم عرض الطريق وانخفاض سرعة المحرك لا يمكن المحافظة على السرعة في العتاد الحالي. الحفاظ على زيادة فتح خنق حتى يتغير مربع بانخفاض والعتاد. وهناك شكوى محددة هو عندما تسلق تل طويلة مربع تتغير من E2 إلى E3 والعودة مرة أخرى. والسبب في ذلك هو أنه في E3 ليس هناك ما يكفي من القوة للحفاظ على السرعة ، لذا يجب إبطاء ، والتغيرات مربع أسفل إلى E2 ، الآن ليس هناك ما يكفي من القوة لتسريع لكم ما يصل إلى النقطة التي تستطيع تغيير لE3 ، و وتبدأ دورة أخرى. لتجنب هذه الدوامة مزعج ، فقط البوب إلى الوضع اليدوي والبقاء في E2 حتى تصل إلى قمة التل ، ثم العودة الى وضع البريد.
الانتقال إلى manouvering ، وخصوصا الى الوراء ، في محاولة للحصول على مخلب تشارك بشكل كامل إذا كنت تستطيع. إن لم يكن ، لا تقلق ، سيكون هناك قليلا من رائحة ، مثل حرق المطاط أو الساخنة. هذا أمر فظيع ، ولكن من الطبيعي تماما. منذ وحات الاحتكاك مخلب لم تعد تحتوي على الاسبستوس ، لأسباب تتعلق بالسلامة ، فإن البديل الاحتكاك وتنتج هذه المواد في استخدام رائحة فظيعة. رائحة سوف تفريق بسرعة. إذا كنت مسافرا حتى تلة ، إلى الأمام أو الوراء ، ببطء شديد بحيث مخلب هو الانزلاق في كل وقت ، سوف يسبب رائحة الدخان ، وربما وربما الضرر. ليس هناك أجهزة استشعار الحرارة في مخلب ، وبالتالي فإن النظام يعمل بها درجة الحرارة النظري من العمل الذي تقوم به. إذا مخلب اسخن أصوات إنذار ، ثم توقف واسمحوا تهدئة الامور قبل المضي قدما.
القراءة جين بعد عن نزول المنحدرات الجبلية ، وعندما ترى وحدة التحكم خنق تراجعت ، الاقدام على الفرامل وتباطؤ ، فإنه سيتم تغيير أسفل بالنسبة لك لانتاج محرك الفرامل. مرة سرعة تحت السيطرة محاولة تخفيف قبالة الفرامل ، والسماح للمحرك قيام بهذا العمل من تباطؤ أنت إلى أسفل. عند الوصول إلى أسفل التل ، وسهولة على دواسة الوقود بدلا من لكمة على ذلك ، إذ أن النظام سوف يرى ذلك الطلب على المزيد من الطاقة والتغير باستمرار.
فيما يتعلق أسلوب القيادة ، وانا لا يجري الحرجة من أي شخص لديه مشكلة مع الإرسال مليون طن متري ، مجرد محاولة لإعادة تثقيفهم. كانت لدي للتعامل مع غاضب الزبون سيدة الذي واجه مشاكل مع نظيرها مليون طن متري. القصة المعتادة بين براثن زلة ، ورائحة الدخان وفقدان الدافع. عندما اقترحت أنها سوف تضطر إلى تعديل أسلوب قيادتها ، ذهبت الباليستية وقال لي انها كانت 50 عاما والقيادة لم تكن في حاجة للتغيير الآن. انها لن تصغي اليه وذهب بعيدا جدا التعيس.
أنا آسف جدا للاستماع لجميع المشاكل التي قد تواجهها. آمل أن يكون هذا المنصب ضخمة ربما تكون قد ساعدت على فهم كيف تعمل انتقال وكيفية الحصول على أفضل من ذلك.
راجع للشغل فيما يتعلق الحديثة علب تروس أوتوماتيكية بالكامل : -- عندما تكون سرعة المحرك وسرعة السيارة على الطريق ، بما يوازيه ، ومحول العزم هو يحبس مع مجموعة خاصة وليس هناك من فقدان السلطة. هذا التشبث يفتح حالما يكتشف نظام انخفاض في السرعة على الطرق.
إذا كانت لديك مشكلة محددة تتعلق مليون طن متري ، وانتقال عملياته ، الرجاء نشر هنا وسأبذل قصارى جهدي ليقدم تفسيرا / الإجابة.
هتاف راي
