We never stop refining our TSI technology. Some of our latest ideas for the 1.4 122 PS include:
More ways to save weight. These range from a lightened cylinder head cover and a weight saving per camshaft to the refined design of the cylinder head itself.
Optimised fuel mixture. A new injector with six fuel bores for electronic direct injection helps achieve this. The injector jets have been realigned to give more efficient distribution of the fuel mixture in the combustion chamber.
Charge-air intercooling. The turbocharger has a water-cooled intercooler with a low-temperature circuit independent of the engine cooling system. As a result we've cut the volume of the charge air system by more than half, allowing a high charge pressure to build up much more quickly. This gives improved dynamics because it reduces the time it takes to achieve maximum charge in the combustion chambers.
تمام يا باشا.... الــ122 حصان فعلا تيربو شارجر بس...
و الباقي توين شارجر...
شكراا يا يوكو على التصحيح...
و بعتذر للأستاذ محمد شامي على المغالطه...
