Someone pls translate this useful article about " A guide showing how a car driver can prevent their car from skidding whether driving in normal conditions, on icy or in the wet. to arabic.
The link to the article = Safe Driving - Prevent Your Car From Skidding
here i would like to higlight
"Braking hard on a slippery road can also cause your car to skid. Your wheels can lock up and you will continue onwards with little or no braking effect. The locked wheels will also prevent you from steering. If this happens you should release the brake pedal to free the wheels then reapply the brake less harshly. If your car has ABS fitted then your wheels won't lock. However don't think ABS eases all problems when driving on a slippery road. It doesn't.
On a slippery road if you approach a corner too quickly there is a good possibility that your car will skid. This is even more likely if you also brake harshly whilst taking the corner. You turn the steering wheel to corner but there is no response and the car continues on ahead. This is a classic front wheel skid. If this happens then remove your foot from the accelerator. This throws the weight balance of the car forwards and helps the tyres find grip. Do not use the brake. As the tyres find grip carefully steer the car into the direction of the skid. For example if the rear of the car skids to the left, steer quickly and smoothly to the left.
