اضف علي كلامك ياا احمد المعلومات دي عن المواتير ال101 او ال102 حصان ونزلت في عربيات ايه من فولكس وفئات المواتير دي ايه من الويكيبيديا وان كنت معرفش كامة واحدة ولا اتنين لكن مكتوب SOHC زي مانت شايف تحت
1.6 R4 74-75kW
identificationparts code prefix: ???, ID code: AHP (75 kW)engine displacement & engine configuration1,595 cubic centimetres (97.3 cu in) inline-four engine (R4/I4); bore x stroke: 81.0 by 77.4 millimetres (3.19 in × 3.05 in), stroke ratio: 1.05:1 - oversquare/short-stroke, 398.8 cc per cylinder, compression ratio: 10.3:1cylinder block & crankcasealuminium alloy aluminium alloy; five main bearings, die-forged steel crankshaftcylinder head & valvetraincast aluminium alloy; two valves per cylinder, single overhead camshaft (SOHC)fuel system & engine managementmulti-point electronic indirect fuel injection with four intake manifold-sited fuel injectors; Bosch MD 7 electronic engine control unit (ECU)electronic indirect injection Total Flex gasoline or ethanol (Brazil)
DIN-rated motive power & torque outputs, ID codes74 kilowatts (101 PS; 99 bhp) @ 5,800 rpm; 135 newton metres (100 ft·lbf) @ 4,400 rpm — AEK (10/94-12/95) - Golf, Vento, Passat74 kilowatts (101 PS; 99 bhp) @ 5,800 rpm; 140 newton metres (103 ft·lbf) @ 3,500 rpm — AFT, AKS (discontinued)74 kilowatts (101 PS; 99 bhp) @ 5,300 rpm; 140 newton metres (103 ft·lbf) @ 3,800 rpm — ADP, AHL (discontinued)74 kilowatts (101 PS; 99 bhp) @ 5,600 rpm; 145 newton metres (107 ft·lbf) @ 3,800 rpm — ANA, ARM, AEH, AKL, APF, AUR, AWH75 kilowatts (102 PS; 101 bhp) @ 6,300 rpm; 135 newton metres (100 ft·lbf) @ 3,500 rpm — ABB (discontinued)75 kilowatts (102 PS; 101 bhp) @ 5,600 rpm; 148 newton metres (109 ft·lbf) @ 3,800 rpm — ALZ, AVU, AYD, BFQ, BFS, BGU, BSE, BSF, CCSA
applicationsAudi: Audi A3 Mk1 & Mk2 (AEH: 09/96-06/01, AKL: 08/97->, APF: 06/99-08/00, AVU: 05/00-04/02, BFQ: 05/02-06/03, BGU: 05/03-05/05, BSE/BSF: 06/05->, CCSA: 07/08->), Audi 80 (ABB: 08/90-05/93), Audi A4 B5, B6 & B7 (ADP: 11/94-10/96, AHL: 10/96-07/99, ANA: 08/98-06/00, ARM: 08/98-10/91, ALZ: 06/00-06/08), Audi 100 (ABB: 03/92-07/93)SEAT: SEAT Ibiza Mk2 (AFT: 09/95-06/99, AKL: 06/99-05/02, AEH: 01/00-05/02, APF: 03/00-10/00, AUR: 07/00-05/02), SEAT Córdoba Mk1 (AFT: 09/95-06/99, AKL: 06/99-08/02, AEH: 01/00-08/02, APF: 03/00-10/00, AUR: 07/00-08/02), SEAT León Mk1 & Mk2 (AEH: 08/99-10/05, AKL: 11/99-10/05, BFQ: 10/05-06/06, BSE/BSF: 07/05->, CCSA: 07/05->), SEAT Altea (BGU: 03/04-05/05, BSE/BSF: 05/05->, CCSA: 12/07->), SEAT Toledo Mk2 & Mk3 (AFT: 09/96-03/99, AKL: 10/98-07/04, AEH: 11/98-07/04, BGU: 02/04-03/06, BSE/BSF: 05/05->, CCSA: 12/07->), SEAT Exeo (ALZ: 03/09->)Škoda: Škoda Octavia Mk1 & Mk2 (AEH: 12/97->, AKL: 08/98->, AVU: 08/00-04/02, BFQ: 04/02->, BGU: 05/04-05/05, BSE/BSF: 05/05->, CCSA: 11/07->)VW/VWCV: Volkswagen Polo Mk3 (AFT: 12/95-08/99, AEH/AKL: 10/99-09/01, APF: 03/00-10/00, AUR: 07/99-09/01), Volkswagen Golf Mk3 (AFT: 07/95-10/00, AKS: 04/97-10/00), Volkswagen Golf Mk4 (AKL: 10/97-05/04, AEH: 01/98-05/04, APF: 05/99-04/01, AVU: 09/99-04/02), Volkswagen Golf Mk5 (BFQ: 05/02-06/06, BGU: 01/04-07/07, BSE/BSF: 05/05->, CCSA: 11/07-12/08), Volkswagen Golf Mk6 (CCSA: 01/08->), Volkswagen Vento (AFT: 01/96-12/97, AKS: 04/97-12/97), Volkswagen Bora (AKL: 08/98-05/05, AEH: 09/98-05/05, APF: 05/99-09/00, AVU: 09/99-04/02, BFQ: 05/02-05/05), Volkswagen Jetta (74kW AHP: 05/98-01/02, BGU: 05/04->, BSE/BSF: 08/05->, CCSA: 01/08-07/10), Volkswagen Touran (BGU: 07/03-05/05, BSE/BSF: 06/05->), Volkswagen New Beetle (AWH: 11/99-10/00, AYD: 06/00->, BFS: 06/02->), VW Passat B4, B5 & B6 (AFT: 12/95-12/96, ADP: 01/97-10/97, AHL: 10/96-08/00, ARM: 01/99-08/00, ANA: 07/99-08/00, ALZ: 10/00-05/05, BSE/BSF: 05/05->), Volkswagen Caddy Mk3 (BGU: 04/04-05/05, BSE/BSF: 06/05->)
