المشاركة الأصلية كتبت بواسطة asaber
انا جالي اكتئاب بعد ما شوفت الكلام ده
C 180 BlueEFFICIENCY: as a temporary measure, if the recommended fuel is not available, you may also use unleaded petrol with an octane rating of 93 RON/83 MON.
All other models: as a temporary measure, if the recommended fuel is not available, you may also use unleaded petrol with an octane rating of 91 RON/82 MON. This may reduce engine performance and increase fuel consumption. Avoid driving at full throttle.
AMG vehicles
Only refuel using super unleaded petrol with at least 98 RON/88 MON that conforms to European standard EN 228 or an equivalent specification.
You can otherwise impair engine output or damage the engine.
Premium-grade unleaded petrol with an octane rating of 95 RON/85 MON may be used as a temporary measure if the recommended fuel is not available. This may reduce engine performance and increase fuel consumption. As much as possible, avoid driving at full throttle.
Regular unleaded petrol with an octane rating of 91 RON/82.5 MON may also be used as a temporary measure if the recommended fuel is not available.
Doing so results in noticeably higher fuel consumption, and the engine power output is noticeably reduced. Avoid driving at full throttle.
If only regular unleaded petrol with an octane rating of 91 RON/82.5 MON or lower is available, you must have the vehicle adapted to this fuel at a qualified specialist workshop.
واللي يشل بقي ان العربيه ال AMG ال8 سلندر تاخد بنزين 92
وانا الوحيد اللي لازم اقل حاجه 93 ...... مش بس كده
دا ال AMG لو عايز ممكن في التوكيل يعدلوا له العربيه وتمشي ببنزين اقل من 91 يعني يفول 90 لو عايز
