صفحة 11 من 20 الأولىالأولى ... 6 7 8 9 10 11 12 13 14 15 16 ... الأخيرةالأخيرة
النتائج 101 إلى 110 من 191
  1. #101
    الصورة الرمزية horas3000
    رقم العضوية : 32723
    الاقامة : Kuwait- Naser city
    السيارة: Renault Fluence 11- Outlander 08- Murano 06- BMW X5 10 - BMW 740Li 06
    السيارة[2]: Mitsubishi Pajero 10
    دراجة بخارية: non
    الحالة : horas3000 غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة hussein_ramdan مشاهدة المشاركة
    هو خلاص القرار اتنفذ؟؟؟؟
    ايوه يا باشا
    من امبارح
    اقتباس المشاركة الأصلية كتبت بواسطة asaber مشاهدة المشاركة
    انا جالي اكتئاب بعد ما شوفت الكلام ده
    C 180 BlueEFFICIENCY: as a temporary measure, if the recommended fuel is not available, you may also use unleaded petrol with an octane rating of 93 RON/83 MON.
    All other models: as a temporary measure, if the recommended fuel is not available, you may also use unleaded petrol with an octane rating of 91 RON/82 MON. This may reduce engine performance and increase fuel consumption. Avoid driving at full throttle.
    AMG vehicles
    Only refuel using super unleaded petrol with at least 98 RON/88 MON that conforms to European standard EN 228 or an equivalent specification.
    You can otherwise impair engine output or damage the engine.
    Premium-grade unleaded petrol with an octane rating of 95 RON/85 MON may be used as a temporary measure if the recommended fuel is not available. This may reduce engine performance and increase fuel consumption. As much as possible, avoid driving at full throttle.
    Regular unleaded petrol with an octane rating of 91 RON/82.5 MON may also be used as a temporary measure if the recommended fuel is not available.
    Doing so results in noticeably higher fuel consumption, and the engine power output is noticeably reduced. Avoid driving at full throttle.
    If only regular unleaded petrol with an octane rating of 91 RON/82.5 MON or lower is available, you must have the vehicle adapted to this fuel at a qualified specialist workshop.
    واللي يشل بقي ان العربيه ال AMG ال8 سلندر تاخد بنزين 92
    وانا الوحيد اللي لازم اقل حاجه 93 ...... مش بس كده
    دا ال AMG لو عايز ممكن في التوكيل يعدلوا له العربيه وتمشي ببنزين اقل من 91 يعني يفول 90 لو عايز
    انا حمايا معاه ال c250 cgi و سال في التوكيل و قالوله مفيش مشاكل من ال 92
    و انا نفسي بصيت علي التانك و لقيت اانها تاخد من 91-98
    معقول ال 180 لازم 93 ؟؟؟
    Sharief Mansy شريف منسي
    شكرا نايل موتورز
    Farewell my Cayenne, you were the best car i ever had and driven
  2. #102
    الصورة الرمزية eleanor
    رقم العضوية : 109288
    الاقامة : any country
    السيارة: بيجو 508
    السيارة[2]: بيجو 505
    الحالة : eleanor غير متواجد حالياً
    اولا السلام عليكم
    انا كنت عايز اقول ان التسقيفة البسيطة دى مع الوقت بتعمل تاكل فى الكرنك بتاع الموتور
  3. #103
    السيارة: بيجو 508
    اقتباس المشاركة الأصلية كتبت بواسطة formulator مشاهدة المشاركة
    شوفوا كده المشاركتين دول، :f_eyeb1[1]:
    لأخوكم فـ الـ95 لحد مانشوف هنعمل أيــــــــه ؟؟
    http://www.nilemotors.net/nile/3874636334-post19.html
    http://www.nilemotors.net/nile/3874639385-post34.html
    @ ahmed.fahmy
    للأسف ياصديقى الفرق كبير فعلا فـ كيفية الإحتراق زى مانت بتقول!!
    الـ95 بيتحرق بـ regular combustion/ smooth-burn
    rather than الـirregular-explosion بتاع الـ92 >>> صباح الـknock/detonation؟؟!!!
    وطبعا: أنا رأيى ان العبوة بتاع التوكيل (كل 5000 كم) إشتغالة كبيرة!!
    مش هتكون أكثر من fuel system cleaner/octane-booster فيها mmt أو mtbe بتركيز قليل متذوبة فـ كيروسين؟!!!
    - أصله مش هيخترع ولا هيجيب الأوكتان من ذيله؟؟!!! هههههههههههههههه
    مكانش حد غلب! انت فاهم بقى عشان كلمة 95 بقت تخوف العميل قبل مايشترى العربية، ماهو لازم يقول كده؟!!
    وبردو الموضوع مش مجرد detergents فـ البنزين الـhigh-octane، التركيبة معقدة أوى:
    مابين boosters و oxygenates و knock-resistance additives ووو...etc؟؟!!!
    شوفوا اللينكات وبعدين نتناقش، الـ92 -فـ تقديرى- هيبقى كارثة فـ المواتير دى حتى بالـover-servicing؟!!
    يعنى انا كنت هاجيب بيجو 508 خلاص وماعنديش بنزين 95 فى الاقصر اشتريها ولا اعمل ايه
  4. #104
    الصورة الرمزية asaber
    رقم العضوية : 348
    الاقامة : Cairo - Mansoura
    السيارة: Mercedes Benz C200k
    السيارة[2]: Mercedes Benz C180 CGI
    الحالة : asaber غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة horas3000 مشاهدة المشاركة
    ايوه يا باشا
    من امبارح
    للاسف دا اللي مكتوب (بالنسبه للموتور الجديد من اول موديلات 2013)
    انا كل محسبها ابقي مش مصدق ..... انا بفول كل 6 ايام مره.
    Ahmed Saber
  5. #105
    الصورة الرمزية Formulator
    رقم العضوية : 25055
    الاقامة : Nasr City
    السيارة: Quadrifoglio Verde
    السيارة[2]: Fiat Bravo T-Jet 09
    دراجة بخارية: .
    الحالة : Formulator غير متواجد حالياً
    Talking -
    اقتباس المشاركة الأصلية كتبت بواسطة enas007 مشاهدة المشاركة
    طيب هوهconsiderable loss of power يعني حوالي كام ؟؟؟؟؟؟؟
    والله ياباشا.. إحنا كنا بنقول ان مع الـ95 نفسه: المواتير الـ150 حصان تنزل لـ140+ حصان!!
    إنما مع 92 أوكتان... الله أعلم؟!!!
    بس كده مش أقل من 15-20 حصان Loss مع الزفت الـ92
    - الـLimit بقى اللى الـECU هتنفض عنده للـknock.. (لأن الـthreshold بيعلى فـ الـAcceleration والـFull-throttle) وهتكمل boost.. كام؟؟ بردو معرفش!!
    اقتباس المشاركة الأصلية كتبت بواسطة Hosam_Optrawy مشاهدة المشاركة
    طيب اسمحولنا نتطفل عليكم يا اهل التربو :) واسألكم عن العربيات اللى ال Comprssion Ratio بتاعها 11 سواء Direct Injection او لأ زى الفوكس والشارك والفييستا والايفو وال C4 وال 308 والسبورتاج وغيرهم , وهل الضرر هايكون اكبر لل Direct Injection + ال Compression Ratio 11 ولا مش هاتفرق
    ولو ال Compression Ratio وصل ل 10.8 زى ال Ecotec بتاع الاسترا او10.7 زى القاشقاى والجوك يمشى معاه 92 عادى ولا لأ
    أعتقد العربيات دى ياحسام المشكلة مش هتبقى كبيرة بالنسبة لهم؟!!!
    لسبب بسيط جدا..
    ان مواتير التربو نظريا الـCR بتاعها أقل، لكن فعليا الـEffective-Compression ratio فـ الموتور التربو اللى CR بتاعته أقل من 10.0:1 بتوصل 20.0:1 مع الشحن التوربينى!!
    ودى المصيبة!
    - حتى الـDirect-injection N/A المشكلة هتبقى فـ الـcarbon-deposits عـ الصبابات، لكن مشكلة الـknock مش هتبقى بحجم مشكلة التربو؟!!!
    اقتباس المشاركة الأصلية كتبت بواسطة Ahmed.Fahmy مشاهدة المشاركة
    المضحك جدا جدا بقى لما نوصل لشكل نهائى للتركيبة و لما واحد فينا يروح يفول الراجل بتاع البنزينة يلاقيه فتح شنطة العربية ومطلع شوية حاجات عمال يحط منها على بعض فى التنك.... الراجل كدا هيقلق...
    - بردو فكرت فيها؟!!! ههههههههههههههههههههه
    ممكن تقف قبلها (برا البنزينة)، وتحط الـmix بتاعك.. وبعدين تخش!! هههههههههههههههه
    ياعم دانا لما كنت بحطها عـ الـ95 (أيام ماكان رخيص )، كان الشارع كله بيتفرج عليا؟؟!!!
  6. #106
    رقم العضوية : 25055
    الاقامة : Nasr City
    دراجة بخارية: .
    Exclamation -
    الجملة دى تجيب إحباط فعلا!!
    هو أنا جايب عربية تربو عشان أمشى partial-load جنب الحيط
    لكن دى.. مكن تجيب شلل؟!!!
    هو فعلا الـAMG////// عشان السوق بتاع أمريكا-الشمالية -ستوك أو adopted- تشتغل 87 AKI بتاعهم (92 عندنا)؟!!!
    موتور V8 Normal-Aspirated وسعات up-to 6.3 Liters.. بيقولك Oldschool تشتغل 92!!
    هو فيه Rule-of-Thumb فـ الحتة دى:
    كل ما الموتور صغر Downsized وإتشحن أعلى Overboosted.. كل ما متطلبات الـhigh-octane بقت A MUST؟؟!!!
    يعنى ممكن جدا -فـ رأيى:
    - الـC180 موتور 1.6 بيطلع 156 حصان.. لازم 95-98 عشان يطلع الـFull Power
    - الـC250 موتور 1.8 بيطلع 185 حصان.. ممكن أوكتان أقل، وبنفس الـrule النسخة الـ204 حصان Overboosted/ Tuned-up يبقى high-octane؟!!! وهكذا
    مثال تانى VW-Audi
    - الـ2.0 TSI والـ1.8TFSI بتاع الـGTi والـA4 بيقولوا على VWVortex ان متطلبات الأوكتان بتاعتهم أقل من الـ1.4 TSI.. عشان الأخير بيطلع Specific-Output أعلى (بالنسبة لحجمه)
    للأسف هى قاعدة صحيحة!!
  7. #107
    رقم العضوية : 25055
    الاقامة : Nasr City
    دراجة بخارية: .
    Talking -
    for all the OVERBOOSTERS
    Ffffffffffffffff them all اللى رفعوا البنزين لـ5.85
    let their Premium-Unleaded go to HELL worth burning
    Now we can go 96+ for Less-Than 200L.E./tank 60L
    هو ليه نحصر تفكيرنا فـ الإضافات الـAnalytical/Pharmaceutical-grade
    ماهو فيه Tech-grade أو Industrial-grade
    والـpurity عالية بردو (95-98%)
  8. #108
    رقم العضوية : 25055
    الاقامة : Nasr City
    دراجة بخارية: .
    Lightbulb -
    والله العظيم الموضوع مش disappointing زى ماكنا فاكرين -فـ أول shock
    لعله خير ان-شاء الله
    أصلا مين كان يضمن اللى كنا بنحطه ده 95؟؟!!!
    (بنفس المبدأ -عارف: وأيه يضمن ان الـsubstrate اللى هنشتغل عليها دى 92)؟؟!!!
    بس الغش هيبقى worth-it دلوقتى فـ الـ95!!
    والبنزينات عندها نفس الـconcept المتخلف بتاع الحكومة: يابيه اللى بيحط 95 ده راكب عربية بـ1/2 مليون جنيه
    - هو أصلا بيقولك عايز كام؟؟ وبيدفع من غير مايبص ؟؟!!!
    ههههههههههههههههههه
  9. #109
    الصورة الرمزية lth586
    رقم العضوية : 123716
    السيارة: lanos
    السيارة[2]: Peugeot 3008
    الحالة : lth586 غير متواجد حالياً
    [QUOTE=Formulator;3874661530]
    ايوه فين التركيبه فين الدماغ علي راي فيلم عبد الحليم حافظ
    نشتري ايه ومنين؟
  10. #110
    الصورة الرمزية dr.hazem
    رقم العضوية : 68443
    الاقامة : الأردن
    السيارة: chery QQ3
    السيارة[2]: suzuki maruti
    دراجة بخارية: suzuki 2002
    الحالة : dr.hazem غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة midnightman_74 مشاهدة المشاركة
    طب ٨ جنية يعملوا كام بعملة الأردن؟؟؟
    دينار أردني علما بأن راتب الطبيب لا يتعدى 500د
    راتب المعلم 300د
    راتب الممرض 200-350
    تحياتي
    Sent from my SE Arc S using Forum Runner
    hm414 سابقا
  1. ماذا سيفعل من معه سيارة بها محرك تيربو فى غلو سعر البنزين 95-مناقشة
    بواسطة Waleed_Fathy في المنتدى أخبار السيارات في مصر والعالم
    مشاركات: 82
    آخر مشاركة: 11-01-2013, 09:41 PM
  2. ماذا سيفعل الشعب فى الايام القادمة؟؟؟؟
    بواسطة محمد عز في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 1
    آخر مشاركة: 30-01-2011, 04:54 PM
  3. ماذا تعرف عن كارل ديزل مخترع اول محرك ميكانيكي وأول محرك سيارة ؟
    بواسطة كابوس الليل في المنتدى القــــسم التعلــــيمى
    آخر مشاركة: 06-07-2010, 06:27 PM
