رقم العضوية : 96900
الاقامة : october
السيارة: geeely ck2
السيارة[2]: 131
دراجة بخارية: 159753
رقم العضوية : 164494
الاقامة : في الدنيا الواسعه
السيارة: chev lanos
السيارة[2]: lancer EX
دراجة بخارية: have not
رقم العضوية : 96900
الاقامة : october
السيارة: geeely ck2
السيارة[2]: 131
رقم العضوية : 96900
الاقامة : october
السيارة: geeely ck2
السيارة[2]: 131
رقم العضوية : 96900
الاقامة : october
السيارة: geeely ck2
السيارة[2]: 131
filter oil MANN W68 / 1; MAHLE (Knecht) OC216, etc.
Fuel filter Nipparts J1332024; FILTRON PP895, etc.
Air filter FILTRON - AR 125
Candles Denso K16R-U, K16-TT
washer to adjust the thermal backlashes in valves diameter 28mm. Toyota Carina, Avensis, King, Selick.
Timing Belt 1) 117MY21. 2) CT 827 117Z (corolla 1.6 08/89 - 04/92)
alternator belt 1987947918
Belt conditioner -1987947894
Belt GUR -3PK-515
roller-tensioner timing belt rollers LuK 531018120
roller-conditioner belt tensioner roller bearing : 6203 (ball bearings, single row, indoors).
perёd brake pads car with ABS-36658
anthers guides 113-1321 caliper
brake pads rear ABS 04495-87704-000
FRONT hodovka:
-tyaga Tie - 45503-87708-000 and left and right (the same)
-Salniki In rail Otaka, Kit:
-Emmetec GL 9001 KIT + this one gland 19h35h6 goes to the steering rack Nissan Blyubird. Code 49265-6N000
-stoechki front staba- Sidem 5663 and 5662 Sidem These racks are left to the right side and the right to his left. In Reno, they are not set in Otake.
-Tormoznye Wheels perёd -
ROADHOUSE 6363.00
BREMBO 08.5878.10
- Support for the front rack itself is also code for Sasic 0385235
Silent large rear lever (front)
right-J40504COEM,
left- J40504BOEM
Silent small front lever (front)
54551-22000
Hyundai / KIA 54571 22000 - bracket holding back Hob front lever (ie, large)
-Stupichny Bearing perёd- 90043-63214
ball joint - CI-BJ-3354
-nakonechniki rulevye- 45046-87782-000 right
-Nakonechnik steering - 45047-87782-000 left
-resistant:
1.-The easiest option, repack the rack!
2. The cartridge rack (if remodel a collapsible)
Caiabu 664,014 (golfovsky liner front)
If modifications are necessary to build a glass rack and steal the course of breakdown of 4-5 cm., so it is advisable to supplement the alteration stiffer springs.
3.-amo perёd Absorber KYB 333506 from Hyundai Getz-F®
Absorber KYB 333507 from Hyundai Getz-F (L).
It is the right and left of the rack. Series racks KYB Excel G
Racks melts with no significant modifications + expedient perfect balance with the more rigid springs so to have hyundaevskih racks considerably less progress in the probe.
-pruzhiny racks before: Monroe SP2505;
-vtulka stabilizer front - HONDA CIVIC since 1996. 51306S04N01
-Otboynik Front Amica with anther
-SACHS (900001)
bearing upper support: Lemforder 31405 01 (405, Citroen Ksara, RenoLaguna)
BACK hodovka:
-Rear small stands stub Toyota Land Cruiser 100, 48820-60032
-opora under the rear rack - support hyundaya emphasis (on that rack fits)
analogs silent blocks zadnіh transverse richagіv.
I give їhnі Cody: 52773-25000 - tse Hob s Malimo opened
i opened the GRAND de robitsya rozval HYAB-AC219, 55219-25100, JK5-516MP. Tsі saylentbloki od Hyundaya Accent Year 1999-2006. Located on the same mashinі de i nashі.
Also od tsogo Well Hyundaya pіdhodyat sleeve reactive rod-5511925000
-podshipniki rear tapered rear hub 713 6102 40 (set)
Racks:
-1.PEREPAkovat rack!
-2.Kartridzhi rack (if remodel a collapsible)
It is desirable to perfect balance with the installation of a hard and short springs!
-3.Stoyka back (Hyundai accent 99-2006 s) Geely CK: KYB332109 - left, KYB332108 - right, set, but only one - should be the hub on both sides by 1.75mm cut down as well, one to one.
-pruzhiny racks ass: Monroe SP2498.
The trailing arm rear bushing sleeve = rear shock VAZ2108 № 2108-2915446-01.
-vtulka rear stabilizer - HONDA CIVIC since 1995.
52315-SK3-010
-Tormoznoy Rear cylinder (with ABS) Geely CK (Toyota) 3502135005/3502140005
Kit brake cylinder rear Seinsa D3164-19mm Seinsa D3415-17,5mm
ELECTRICITY:
- bearing genes = Bearing Similar Containers of genes Deviatiny.
-shokoladka and brushes geny- 94323702 (one block)
diodes bought 5 UAH on the radio. common.
-Schёtochny Starter unit, one to one from 2110
-Bosch 0580454001-fuel pump.
-ALT5041- Analogue of genes for MC and SC
Seeing-vysokovoltnye- 90998-99002, TSN 1.4.30 (thick, excellent quality)
-analog Retractor on the starter checked personally, relays, one to one from 2110, the difference in the mounting holes, we have 2 pieces. in vazovskaya 4pcs. Manufacturer Manufacturer - "Electron"
Zapalennya module "(Bosch № 0221 503 465 is the number on the module)
-Benzonasos with pelvic tithe
-Motorchik Washer From Lanos
-sensors throttle position From the "Volga" GAZ 3110: Bosch 0280122001.
-regulators idle hoda- Chery Amulet
CAT S160
Bearings
NSK 6208-100gr
NSK 6305 (2 pieces) -85gr
30204-80gr NSK
NSK 32006-120gr
SKS 6308-165gr
-Soldatik Fork of the stage 2101-1601215
-Vyzhimnoy bearing on the Yaris 99-02 years vypuska.odin one. such a
BT-021
-pylnik fork stsepy- 31126-12051
OTHER:
incubator toyotovskih 82 degrees = 90916-03046
90916-03063 = 88 Degrees
-pruzhinka in the scenes to secure the stick-mixer - 90508 -20084 existu on its way as a gasket :), but it is spring!
-rezinki suspension exhaust system - from Lanos
-Podshipnik pump GUR 6303
-motorchik pisyalki- with Lanos
-remkomplekt master cylinder
D1292
-krestoviny steering shaft = cross steering shaft from the WHA 2105
Dvigalishko:
The Chinese in dull copied Toyota 5a-fe, stuck DIS2 ignition system and strangled him in the euro 4
References on sites do Thun zips for Otaka and selling analogues of production is not China!
geelygroup.prom.ua/g45236...-zapchasti-evropy-yaponii
a-tuning.net/pu/geely/ck.htm
رقم العضوية : 96900
الاقامة : october
السيارة: geeely ck2
السيارة[2]: 131
رقم العضوية : 153068
الاقامة : الاسكندريه
السيارة: هونداى
السيارة[2]: بولينيز
شكرا يا حبيبى على هذه المعلومات الجميلة والحقيقة اذا توافرت قطع الغيار الجيدة فان هذه العربية جميلة ..ولك جزيل الشكرا
رقم العضوية : 70048
الاقامة : الجيزة
السيارة: !!!!!!!!!!
السيارة[2]: جيلى ck2
رقم العضوية : 70048
الاقامة : الجيزة
السيارة: !!!!!!!!!!
انا اشتريت تيل فرامل امامى اسبرنزا a620
75 جنية وركبتهم والحمد لله تمام
elbadry99 سابقا
رقم العضوية : 96900
الاقامة : october
السيارة: geeely ck2
السيارة[2]: 131
