عموما في فتي حاصل ههههههههههههههههههههه .. شوف اهي دي فولكس امريكا كاتبة مواصفة مختلفة شوية للمية A8F وليس A8D !
PURPLE مش RED زي الكاتلوج او حتى PINK زي جماعتنا ( معليش الصورة مش واضحة لكن نسخت لك جزئية المية من البي دي اف )
¤COOLING SYSTEM: Use only phosphate free coolant G 012 A8F A4, PURPLE COLORED. DO NOT INTERCHANGE OR MIX older G 11(ZVW 237 105), GREEN
COLORED. This can result in serious damage to the engine. However, it may be mixed with ZVW 237 G12, PINK COLORED. Frost protection is required down
to approximately -25_C (-13_F). In countries with arctic climates, frost protection is required down to approximately --35_C (--31_F). The anti-freeze ratio must
be a minimum of 40%, as otherwise frost protection is reduced. The recommended mixture ratio is 50:50. If greater frost protection is required (very cold climates),
the amount of G 012 A8F A4 can be increased, but only up to 60%. This provides frost protection to approx. -40_C (--40_F). Do not reduce the coolant concentration
by adding water, even in warmer seasons and in warmer countries, as cooling effectiveness will be reduced.
