For optimum cooling, it's best to use the smallest proportion of anti-freeze commensurate with your local temperatures and block materials. 10%-20% of anti-freeze will help prevent internal corrosion, especially when using an aluminum block or heads.
For short term use, pure water has the best heat transfer rate of all. We've had good results by adding Red Line Water Wetter too
