ازيك يا دكتور شريف
لو فاكر حضرتك كنت استنشرتك في موضوع الوالدة
احنا رحنا معهد الرمد وعملنا visual field and oct
ودي النتايج
مجال الابصار عدناه مرتين لان الجهاز كان بيطلع errors حسب كلام الدكتورة وبيقول ان patient is incooperative
[OVERLINE]right test showed[/OVERLINE]
good test reliability
area of significant localized depression of retinal sensitivity involving the upper hemifield as seen in total and pattern deviation plots.mean deviation(-2.32dB,p<5%)
pattern standard deviation (2.29dB,p<5%
GHT is borderline
[OVERLINE]left test showed[/OVERLINE]
area of significant localized depression of retinal sensitivity involving mainly the upper hemifield
mean deviation(-2.57dB,p<5%)
pattern standard deviation(2.09dB,p<5%
GHT is borderline
[OVERLINE]conclusion[/OVERLINE]
bilateral localized visual defects.clinical correlation,follow up and oct are recommended
