Here are the spec of the radar detector that are used in Egypt
I have emailed the company that manfacture it
I found out that the radar that is used here:
Technical Parameters of AD9 T Speed Camera Equipped with TABLET PC:
Transmitter frequency: 34.3 GHz
Transmitter RF power: typical 0.5 mW, maximum 2 mW
Antenna beamwidth: 5ş
Side lobes: minimum -20 dB
Antenna electrical/mechanical axis deviation: max. 0.5ş
Antenna beam angle relative to
traffic direction: 22ş
Method of measurement : approach, departure, both directions
Maximum range to measured object: 60 m (4 traffic lanes)
Selectable ranges: 60 m, 30 m, 20 m
The range is to be selected from the three values mentioned above which means a distance of the radar antenna of the speed camera from the measured object under the angle of 22°.
Speed measurement interval: 1 km/h
Range of guaranteed measurement accuracy: 20 km/h to 250 km/h
Speed measurement accuracy:
to 100 km.h-1 ± 3 km/h
over 100 km.h-1 ± 3 %
Start of measurement: manually, automatically
Long /short vehicle distinguishment: at approach,at departure
Measured data outputs: display image
file in computer data medium
voice output
Digital camera beam angle relative to traffic direction: 19°
Image resolution: 2 million pixels
Electronic shutter speed: 1/60 to 1/10000
Average file size after compression:1 MB – black-and-white image 1.5 MB – colour image
Compression format: JPG-LS
Lens Minolta AF (24-105 mm, F 3.5 – 4.5)
Identification data on measurement displayed measurement identification
in the image: measured speed
time of measurement
date of measurement
radar range
image number
serial number of the device
speed limits
lens ZOOM
Now the TF is 34.3, so you need detector that can detect small Ka 34.3
the TRF power is only 0.5 MW, so this mean very little power coming out, so also you need to buy something that is good like V1 or Bell Euro model
Please don't buy any kind like Cobra for $60 because it will no do anything.
