ما هو يا معلم من اللى أنا قريته, ده عيب ترموستات.
يا إما اتشالت يا إما فاتحة على طول...لإن مستحيل العربية توصل لمعدل السخونة الطبيعي في 10 دقائق في الحر ومع التكييف.
وبعدين واضح زيادة استهلاك البنزين لأني لسة مفول من نفس البنزين و تنك البنزين قالل عن المرة اللي فاتت بعد 85 كم.
any liquid-cooled car engine has a small device called the thermostat that sits between the engine and the radiator. The thermostat in most cars is about 2 inches (5 cm) in diameter. Its job is to block the flow of coolant to the radiator until the engine has warmed up. When the engine is cold, no coolant flows through the engine. Once the engine reaches its operating temperature (generally about 200 degrees f, 95 degrees c), the thermostat opens. By letting the engine warm up as quickly as possible, the thermostat reduces engine wear, deposits and emissions.a thermostat can also stick open, but most cars don’t have a ‘low engine temp’ light and most people don’t worry about a cool engine temperature. But a thermostat that’s stuck open costs you money every mile you drive.
A 195-degree thermostat that sticks open and reduces the engine coolant temperature to, say, 160 degrees, will allow fuel to condense on the cylinders due to cooler water jacket temperatures. Condensed fuel doesn’t burn properly and you pay a mileage penalty.
