رقم العضوية : 3647
الاقامة : EGYPT / CAIRO
السيارة: CIVIC
السيارة[2]: HONDA CIVIC SIR
دراجة بخارية: HONDA CBR
ياباشا ولا متهور ولا حاجة حضرتك ماشوفتنيش اول لما جيبت العربية كنت بلاقى العربية بتفصل منى على الغيارات عشان كنت بجيب 9500 لفة فى اقل ثلاث ثوانى وكنت بمشى على اى طريق سريع مش اقل من 220 وبزود لو يسمح
انا هديت جدا من اول كمان لما خطبت خلاص بقى الواحد بقى مسؤل
بالرغم من سرعتى الا انى الحمد لله عاقل فى سواقتى جدا وعمرى ماعملت غرزة على حساب اللى ورايا او اللى جنبى
وربنا يستر طريقنا جميعا
SEMSEM KANE سابقا
رقم العضوية : 29426
الاقامة : Netherlands
السيارة: Mini Cooper Chilli 1.6
السيارة[2]: BMW E90 318i LCI N43
رقم العضوية : 29426
المكتوب عن الundersteering ده في ويكيبيديا هو مجرد تعريف لكن عمليا ده اللي بيحصل في الامامي و الخلفي:
Front wheel drive cars generally understeer. That is to say that when turning a corner, the front wheels are performing both the action of changing direction, and moving the car forward. The faster you're travelling, the hard it is for the front wheels to perform both actions at the same time, without causing you to turn in a wider arc than if you'd been driving slower. The wider the arc, the more you're understeering. To counter understeer, you have to reduce speed by lifing off the gas.
Rear wheel drive cars generally oversteer. The rear wheels only move the car forward, and the front wheels only have to change the car's direction. Oversteer means that the arc is much tighter as the rear of the car tries to 'come around' to the front. Worst case scenario is spinning out. You can counter oversteer by applying more speed, and by turning the wheel in the opposite direction -- 'opposite lock'. Lifting off the gas during oversteer will cause a weight transfer to the front of the car, reducing grip at the rear which is not good in a rear wheel drive car.
If you've ever seen 'drifting', where the car is driven around a corner almost sideways, with the front wheels turned in the opposite direction, that's oversteer.
If you're inexperienced with a rear wheel drive car, take it easy. It can take a lot of practice to be able to effectively balance an oversteering car with throttle and steering input. Applying too much opposite lock and the car can begin to oversteer in the opposite direction! Fishtailing is a scary experience!
If you've seen the movie Days of Thunder, they make a reference to the car being 'fast' or 'loose'. 'Fast' means oversteer, and 'loose' means understeer
رقم العضوية : 27285
الاقامة : الكرة الأرضية
السيارة: -Cabrice-LTZ
السيارة[2]: ِAlfa156 seles-جيب جراند شيروكي
أسمحلي أزاي الي مكتوب حاجة والحقيقة حاجة!
إِن يَنصُرْ.كُمُ اللَّـهُ فَلَا غَالِبَ لَكُمْ ۖ وَإِن يَخْذُلْكُمْ فَمَن ذَا الَّذِي يَنصُرُ.كُم مِّن بَعْدِهِ ۗ وَعَلَى اللَّـهِ فَلْيَتَوَكَّلِ الْمُؤْمِنُونَ ﴿160)
م/محمد
رقم العضوية : 27285
العربية دي كانت معايا في يوم من الأيام..........متعدلة أستروكر بالكامل وتيربو طبعا وماكنتش بحس understeer
torque steer طبعا
م/محمد
رقم العضوية : 73936
الاقامة : Haram
السيارة: Ulti-Driving Machine
السيارة[2]: BMW E30 - 316i
رقم العضوية : 3961
الاقامة : شبرا مصر :) اجدع ناس ؛)
السيارة: Alfa Romeo 75 milano
السيارة[2]: Alfa Romeo 75 milano&156&146
دراجة بخارية: ماينفعش تركب بايك في مصر للأسف.
والله العظيم يا باشا انا ولا هاشترى دى ولا دى -المنافسة ليكم انتم-وللناس-لان العربيتين يا ما احتارت فيهم ناس-وفى الاخر من كتر الخوف والرهبة وعدم الوصول لقرار-وفى الاخر بيتجهوا فى مكان تانى يا لانسر كريستالة يا نوبيرا يا لانوس او فيرنا موديل عالى- ومنهم واحد صاحببى جدا-راح اشترى نوبيرا فى الاخر-وضحكنا عليه لما شبعنا.وبكرر المنافسة مش ليا -دى للناس.
My "facebook" Account is "Ahmed Aymn Arbiat"
رقم العضوية : 61593
الاقامة : elm3aadi
السيارة: E36 2000CC
السيارة[2]: E30
دا مش هزار دا اسمو انسحاب تكتيكي
لحد منجمع صفوفنا
ونبداء بالضربه المرتده
طبعا بهزر
الموضوع
اني شايف كل واحد حابب عربيتو
ودا مش غلط
وبما اني بحب عربيتي ومقدر امكانيتها
فاكيد هعبر
وصدقني موضوعك ده من اجمل مواضيع المقارنات
وكله مفيد
بس احب اسال
رجال الهوندا
ايه وضع الهوندا بالنسبه للسوبارو
كعربيتين ياباني؟
وشكرا
رقم العضوية : 3961
يارجالة البى ام-عايزين تجارب واقعية ومعلومات اكتر عنها-ماحدش هايعريف يفيد غير ملاكها-وبلاش سيرة السوبارو هنا -علشان دى وهم تانى وتكنولوجى تانى خالص بمحركاتها البوكسر.خلينا فى
الوحشين بتوعنا
Ice&fire-وربنا يستر علشان رجالة البى ام حضروا.
رقم العضوية : 3647
السيارة: CIVIC
على فكرة سيارة سوبارو امبيريزا موديل 2005
بتاعة صديقى وماشاء الله علية سواق بجد كنا راجعين بليل وقعدنا نشد مع بعض لحد مادخلنا النفق فى طريقنا الى وسط البلد الكلام دة فى العيد اللى فات والنفق كان مفتوح لحد الساعة 1:30
طبعا انا فرقت عنة بكتير فى الشد بس جيت كدة قبل النفق روحت مهدى شوية عشان نبقى قريبين من بعض والحمد لله تم التحدى انا مانكرش ان السيارة ثابتة جدا بس والله كان بيبعد عنى فى كل ملف دة غير انة كان بياخد الملف فى نص النفق وانا ماخرتش عن حارتى والحمد لله خلصت النفق بفرق كبير حوالى عشر ثوانى انا بردة كنت جايب ساعتها 185 كم وماكنش فية غيرنا والله فى النفق
ملاحظات : العربية سليمة مافيهاش مشاكل لانة زى حالاتى كدة بيجرى كتير فبيخلى العربية مظبوطة دايما
قلبة ميت بس بيفرق عنى انة ممكن مايخافش على السيارات المحيطة بية ولو عايز يعمل غرزة هيعملها حتى لو هيخلى اللى وراة يقف
ماشاء الله علية الله ام لا حسد سواقتة جميلة
دية تجربتى مع السوبارو بدون اى مبالغة حتى صاحبى اللى كان راكب جنبى قالة ماتهزرش مع الهوندا ياااااااااااض
SEMSEM KANE سابقا
