رقم العضوية : 28833
السيارة: Mitsubishi Pajero 2010
السيارة[2]: Hyundai Verna 2009
دراجة بخارية: Keine
لا أتفق مع حضرتك
التجربه شيء مختلف ..
ثم أنه
V is equal for both
M is bigger for the mercedes
which means that .. the mercedes will have a more kinetic energy but doesnt necessairly means it needs a longer distance
which also leads to.. with more brake power .. you can make the mercedes stop in the same distance or even less
so CONCLUSION : at the same speed its IMPOSSIBLE that both have same KINETIC ENERGY
but its fairly probable to make them both stop in the same distance
life example
the Kia Cerato is heavier than Hyundai verna ( which i own ) by about 300+ Kilos
and yet the cerato has a more brake power and obviously can stop in a shorter distance
رقم العضوية : 28833
دراجة بخارية: Keine
رقم العضوية : 53443
السيارة: Kia Cerato Sx Smart 2011
السيارة[2]: Opel Astra Enjoy 2009
دراجة بخارية: -
انا متأكد 100% ان التجربة شء مختلف
Mercedes K.E is >Hyundai K.E ,both will have same road conditions so subtract it from both K.E .i think Mercedes will have more Air Resistance and Tyre Friction than Hyundai,because
Friction =u*Reaction from ground which makes the car equilibrium so Rg=Car Weight
Braking power from Merc ofc Bigger than Hyundai,that doesn't mean it will overtake the 2x difference in weight
Here it is with numbers
Both cars at 100km/hr
Mercedes
2000*100²=20,000,000J
Hyundai
1090*100²=10.900.000J
Do you think that the max friction force done and roughest conditions against Mercedes only and the very high braking power will achieve 9,000,000 Joules
even if we take off 5,000,000J off for brakes (i don't know actual number)l
I know Theory is impossible to be accurate but that doesn't mean it is wrong
وطبعا فى الاخر اختلاف الرأى لا يفسد للود قضية:)
رقم العضوية : 28833
دراجة بخارية: Keine
LOOK i dont know the math :D or the physics
but why is it different ??
why is it so obvious that mercedes has a better brake power than hyundai ??
and you better know the actual nombers coz am sure that the mercedes can take all the 20,000,000J away
with all my respect
رقم العضوية : 53443
دراجة بخارية: -
Check This:Vehicle Stopping Distance Calculator
رقم العضوية : 28833
دراجة بخارية: Keine
مش فاهم أوي في الموقع لأني مش مهندس
رقم العضوية : 52198
الاقامة : Cairo - Ksa
السيارة: Renault Logan F/O 2010
السيارة[2]: Kia Cerato koup 2011
دراجة بخارية: None
il n’est pire aveugle que celui qui ne veut pas voir
رقم العضوية : 33117
الاقامة : 6 Of October
السيارة: Peugeot 508 GT Max
السيارة[2]: Range Rover Velar
دراجة بخارية: VTX 1800
المسافات اللى كنت كاتبها بتاعتهم كانت موديلات 2007
L'أ‰quipe: Audi A8 4.2 vs BMW 750i vs Jaguar XJ8 vs Lexus LS460 vs Mercedes S500 - AutoSpies Auto News
بس على فكرة الـ s550 والـ s600 مختلفين شوية عن الـ s500 والـ s320 عشان فيهم وسائل مساعدة اكتر
بس ما شاء الله شوفت الـ s550 مش بتميل خالص مفيش تقريبا bodyroll بسبب الـ active body control .. دا انا حسيت ان البى ام هتتقلب.
على العموم انا بثق فى insideline اكتر فعلا والتقييمات بتاعت السيراتو والسيفيك ومازدا والباقى من على Insideline
بس لما عملت search على الـ s500 ملقتش ليها full review تقريبا عشان عملوا اختبار لـ 550 بس
بس باردوا كاتبين 122.73ft فى الموقع فا اعتقد هما بيكتبوا الـ average يعنى اللى بيحصل فى معظم الاوقات عشان كدا انا بالسيراتو جبت اقل منهم تقريبا بـ 2 متر ولا حاجة
رقم العضوية : 28833
دراجة بخارية: Keine
nice video
thanks
رقم العضوية : 28833
دراجة بخارية: Keine
The heavier mercedes stops in a shorter distance than the lighter BMW
