ملحوظة علي بيانات المحرك...
The Toyota 1ZR-FE is a DOHC, 16 valve, 1.6L (1598cc) engine equipped with Dual VVT-i. This engine is available with either manual gearbox or a "multi-mode" transmission. Output for this engine is rated at 124 hp (92 kW) at 6000 rpm and 116 lb·ft (157 N·m) of torque at 5200 rpm gross.
