المشاركة الأصلية كتبت بواسطة darshing
4G92-MIVEC DOHC 16 Valve
Total Displacement - 1,597 cc
Bore - 81.0 mm
Stroke - 77.5 mm
Compression Ratio - 11:1
Maximum Output - 128 kW (174 PS; 172 bhp) at 7,500 rpm
Maximum Torque - 167 N·m (123 ft·lbf) at 7,000 rpm
شوف حضرتك انا معرفش في مواتير الهوندا فياريت حضرتك تديني رقم موتور الهوندا ال1600 الي بيطلع 175 حصان
انا كتبتلك فوق رقم الموتور ال1600 المايفيك و امكنياته
وعلى فكره انا مش معترض خالص على قصه ان ال 2400 بيولد 162 وده بيناته
The 4G69 is a 2378 cc version built in Shiga, Japan. Bore is 87 mm and stroke is 100 mm. Output is 162 hp (119 kW) at 5750 rpm (160 in the Sportback Wagon) with 162 lb·ft (219 N·m) of torque at 4000 rpm. It has a cast iron engine block and an aluminum SOHC cylinder head. It uses multi-point fuel injection, has 4 valves per cylinder with roller followers and features forged steel connecting rods, a one-piece cast camshaft, and a cast aluminum intake manifold. The 4G69 incorporates Mitsubishi's MIVEC Variable Valve Timing technology
