3 - Engine:
1. The crankshaft
2. The cover of the first main bearing
3. camshaft drive pulley
4. The pulley drive generator
5. The front crankshaft oil seal
6. The oil pump
7. Rod
8. Front protective cover of a gear belt
9 . The piston
10. The inlet valve
11. The exhaust valve
12. belt camshaft
13. Camshaft pulley
14. The rear protective cover of a gear belt
15. Gland camshaft
16. The front housing camshaft bearings
17. camshaft
18. Grid separator crankcase ventilation system
19. Cylinder Head Cover
20. Cover the separator
21. The rear bearing housing camshaft
22. The eccentric drive of the fuel pump
23. The sensor-distributor
24. The case of auxiliary units
25. The discharge pipe cooling jacket
26. Spark Plug
27. The cylinder head
28. The cylinder block
29. Holder with crankshaft rear oil seal
30. Flywheel
31. Bracket with pillar front suspension motor
32. The power unit (engine gearbox and clutch)
33. Bracket with left engine mount support
34. Bracket with support rear engine mounts
35. Support the front engine mounts
36. Arm front suspension motor
37. Oil pan
38. Oil level indicator
39. Plug the oil drain from the crankcase
40. Bracket left engine mount
41. Prop left engine mount
42. Bracket rear engine mounts
43. Support the rear engine mount.
1. The receiver of the oil pump
2. Oil pan
3 . Oil Filter
4. Cylinder Block
5. The exhaust manifold
6. An inlet pipe
7. Inlet pipe coolant pump
8. The thermal screen carburetor
9. Thermostat
10. The fuel pump
11. the oil filler cap
12. head cover
13. The front camshaft bearing housing
14. Camshaft
15. The cylinder head
16. Spark Plug
17. cylinder head gasket
18. The piston
19. The piston pin
20. Rod
21. The insert rod crankshaft bearing
22. Cover the connecting rod
23. Crankshaft
24. valve stem seal
25. The pusher
26. Rusk valve
27. Plate springs
28. Shim
29. The inner valve spring
30. The outer valve spring
31. Supporting disk springs
32. The locking ring
33. Valve Guides
34. The valve seat
35. The inlet valve
36. A.Zazor Is the valve on the cold engine: 0.2 mm for the inlet valves and 0, 35 mm for the exhaust
37. V.Diagramma timing
38. I.Vpusk combustible mixture
39. II.Szhatie
40. III.Rabochy course
41. IV.Vypusk.
The car has four-cylinder four-stroke carbureted engines of various sizes of cylinders, in-line cylinders and a camshaft placed on the cylinder head. The engine is specially designed for transverse location on the front-wheel car.
Therefore, its layout and basic dimensions are selected such that he, along with the gearbox could accommodate between mudguards across the front wheels.
Three standardized engine displacement of 1100, 1300 and 1500 cm * formed by a combination of three different height and diameter of the cylinder block, cylinder head with two different diameter inlet channels and two pistons with different diameter (76 and 82), and two crankshafts shafts with crank radius corresponding to the piston moves 60.6 and 71 mm.
Assembled with gearbox and clutch engine forms a single rigid unit power unit. He is attached to the vehicle at three elastic supports.
They perceive as the weight of the power unit and the stress caused when starting the car from the scene, acceleration and braking. Elastic support absorb vibration engine running and not pass them on to the body, thereby reducing the noise in the car.
On the other hand, the elastic support protect the power unit from strong impact when driving on rough roads. By car adopted a three-point mounting scheme of the power unit consisting of front, rear and left legs.
The front left and have the same bearing apparatus, and consist of a steel outer ring and inner sleeve of aluminum, between which is privulkanizirovannaya thereto tires. Back support is bolted to the bottom of the bottom of the body.
It consists of an outer and inner steel reinforcement aluminum sleeve and separated rubber. Arm rear suspension steel, forged, mounted on the gearbox bolts connecting the clutch with the gearbox case. The cylinder block.
All the cylinders of the engine are combined together with the upper part of the crankcase assembly in a common cylinder block cast from a special ductile iron.
With such an arrangement provides structural strength, rigidity, compactness and reduced weight of the motor. The coolant ducts are made over the entire height of the cylinder which improves the cooling of pistons and piston rings and the cylinder reduces the deformation of the uneven heating.
Cylinder block diameter divided into five classes by 0.01 mm, designated by the letters A, B, C, D. E Class cylinder on the bottom plane of the block against each cylinder. Cylinder and piston mating with him must be the same class.
When repairing cylinders can be bored and othoningovany under increased diameter pistons 0.4 and 0.8 mm. At the bottom of the cylinder are five pillars crankshaft bearing with thin-walled steel reinforced liners. The upper and lower liners medium (K-th) main bearing without grooves on the inner surface.
The remaining upper bearing inserts with a groove on the inner surface, and the lower - no grooves. Before 1988 the lower liners of these bearings were also grooved.
The bearings have a removable cover 2, which are mounted on the cylinder block self-locking bolts.
Holes for the bearings of the crankshaft in the engine block are processed in the collection with lids that provides high accuracy, a regular geometric shape and alignment holes.
Therefore, the bearing caps are not interchangeable and differences are on the outer surface of the risks in the medium support has slots for persistent half rings 12, holding the crankshaft from axial displacement. On the back side of the middle support is placed cermet semiring (yellow) color), and the front side stadealyuminievoe.
The value of the axial clearance of the crankshaft must be 0,06-0,026 mm. If the clearance exceeds the maximum (0.35 mm), replace the half-ring repair, an increase of 0.127 mm. It should be borne in mind that the grooves are on one side of the half-rings should be directed to the abutment surface of the crankshaft. Bottom crankcase sump stamped steel rose 37. Carter has a partition to calm the oil. Between the oil pan and cylinder block gasket set probkorezinovoy mixture. To the rear end face of the cylinder is mounted clutch.
The exact location of the crankcase with respect to the cylinder block and the alignment of the crankshaft and the gearbox input shaft is provided with two centering bushings pressed into the cylinder block.
The cylinder head 27 is common to four cylinders, cast from an aluminum alloy, has a wedge-shaped combustion chamber. In the molded head valve guides and saddles made of cast iron. Saddles, prechilled in liquid nitrogen, inserted into the socket of the heated cylinder heads. This ensures reliable and robust landing seats in the head. Between the head and the cylinder block has a special shrinkproofing laying on a metal frame.
The head is centered on the cylinder block the two housings and fixed thereto by bolts ten. For uniform compression across the surface of the head gasket to ensure a tight seal and exceptions in the subsequent tightening of bolts in maintenance car cylinder head bolts are tightened evenly without jerks in four stages and in strict sequence; 1 reception tighten the bolts to 2 kg-cm; 2 reception tighten the bolts to 7.08 -8.74 kgcm, 3 reception - dovorachivat bolts 90 '; 4 Reception - again dovorachivat bolts 90 ".
At the top of the cylinder head are five pillars under the neck of the camshaft 17. The supports are detachable. The top half is in the bearing housings 16 and 21 (front and rear), and lower in the cylinder head.
Installation Sleeve bearing housings camshaft placed in mounting studs buildings. The holes in the supports are processed in gathering with the bearing housing so they are not interchangeable, and the cylinder head can be replaced only in gathering with the bearing housing. On the surface of the cylinder head mating with the bearing housing in the area of extreme supports the camshaft is applied sealant KLT-75TM.
Install the bearing housing and tighten the nuts attaching them in two stages: 1st pre-reception tightened the nuts in the sequence shown on the sheet 7 to fit the bearing housing to the cylinder head, taking care to mounting bushing housings freely into their sockets; 2nd reception finally tighten nuts to 2.2 kg / cm in the same sequence.
Timing. Per cycle in the cylinder during the intake stroke occurs four fuel mixture compression stroke and exhaust system. These measures are carried out for two revolutions of the crankshaft, ie each cycle occurs in a half-turn (180 °) of the crankshaft.
The inlet valve starts to open ahead, ie approach of the piston to the top dead center (TDC) at a distance corresponding to 33 'rotation of the crankshaft before
TDC. This is to ensure that the valve is fully open when the piston goes down, and through the fully open inlet received possibly more fresh fuel smesiVpusknoy valve closes with a delay, ie, after passing the piston bottom dead center (BDC) at a distance corresponding to 79 crank angle after BDC.
Due to the inertia of the jet head is sucked fuel mixture continues to flow into the cylinder when the piston has already started to move up, and thereby providing better filling of the cylinder. Thus, the inlet practically occurs during rotation of the crankshaft 292.
The exhaust valve begins to open before the complete closure of the working stroke to the piston approaches BDC by a distance corresponding to 47 'until the crank BDC.
At this time, the cylinder pressure is still quite large, and the gases begin to flow out of the cylinder intensively, whereby their pressure and temperature decrease rapidly.
This greatly reduces the work of the engine during the release and protects the motor from overheating. Issue proceeds and after the passage of the piston TDC, ie when the crankshaft is rotated by 17 'after TDC. Thus, the duration of release is 244 '.
From the phase diagram it is evident that there exists a point (50 'about the crank TDC), when both valves are open simultaneously - the inlet and outlet. This situation is called a camshaft overlap.
Because of the small valve overlap period does not lead to the penetration of the exhaust gases into the intake manifold, and vice versa, the inertia of the exhaust gas flow causes suction of the combustible mixture into the cylinder and thus improves the content.
Described timing occur in the gap between the A cam camshaft and tappets the engine is cold. To ensure coordination of the opening and closing of valves with angles of rotation of the crankshaft (t. E. To ensure correct installation of the valve timing) engine parts are the mark 7 on the back cover of a gear belt; 8 on the camshaft pulley; 10 and 11 on the front cover toothed belt; 12 on the drive pulley of the generator; 13 on the cover of the oil pump; 14 on the crankshaft pinion.
If timing is correctly installed, when the piston is at TDC of the first cylinder at the end of the compression stroke mark 7 on the rear cover of the toothed belt should coincide with the mark 8 on the camshaft pulley and the mark on the toothed pulley 14 of the crankshaft 13 with the label on the lid of the oil pump .
When the cavity of the camshaft drive front cover is closed, the position of the crankshaft can be determined according to the marks on the pulley and alternator drive the front cover of a gear belt.
When the piston in the fourth cylinder TDC mark 12 on the pulley should coincide with a label 11 on the lid of the camshaft drive. In addition, you can use the mark on the flywheel 20 and the scale 19 in the hatch the clutch housing. One division of the scale corresponds to a rotation of the crankshaft G. At coincidence tags adjust the belt tension and a backlash and in the valve mechanism.
Operation of the engine. For smooth operation of the multi-cylinder engine and reduce uneven loads on the crankshaft in different working processes cylinders must occur in the sequence (order). Arrangements for the cylinders of the engine depends on the location of the crankshaft journals and cam camshaft and engine family in 2108 is 1-3-4-2.
The sequence of alternation of cycles in the cylinders of the engine for two complete revolutions convenient to follow the table: When the first piston moves down the cylinder in the range from 0 to 180 ° rotation, combustion takes place and expansion of gases.
During the expansion of gases perform useful work, so this cycle is called the stroke. Third behind the first cylinder 180 'and it moves up the piston, performing compression of the working mixture. In the fourth cylinder lags behind the first 360 'and third 180'. Piston moves downward and the inlet of the combustible mixture occurs.
Finally, in the second cylinder lagging cycle workflow 540 'from the first cylinder at this while the piston moves upwards, and is discharged exhaust gas. Similarly, in a range from 180 'to 360' rotation of the first crank pin stroke occurs in the third cylinder compression fourth inlet - in the second and in the first release, etc.
يتبع
