دة اللى مكتوب فى الكتالوج
The engine oil consumption is affected by a number of factors. The new engine will reach the normal value of consumption after the vehicle has run for approximately 5,000km. The engine will consume more oil under the high-load operation. It is necessary to carry out the regular inspection on engine oil, for example, when adding fuel or before starting a long-distance journey. When inspecting the engine oil, parked the vehicle on the level ground. Turn off the ignition switch and wait a few minutes to allow the engine oil to flow into the oil pan (a longer time may be needed if the exterior temperature is rather low or the engine has not reached the operating temperature). The vehicle engine should not be started before the inspection of engine oil. Pull out the dipstick and wipe it with a piece of clean non-cottony cloth, then fully insert the dipstick and
In case the oil level stays between the MIN and the MAX signs at the lower end of dipstick, there is no need to add the oil again. The hot engine oil may surpass the above gap sign for several millimeters due to the thermal expansion.
In case the oil level is flush with or below the MIN sign, only add the engine oil in line with Chery specifications to make the level stay between the MIN and the MAX signs. See the chapter “Capacity and Specification” for details.
Filling Cover for Engine Oil
Simply rotated anticlockwise and pulled, the filling cover will be open. Do not open the filling cover during the operation of engine.
Close the cover by rotating it clockwise until hearing a click sound.
Do not use the engine oil
additives or engine processing agents. They are not only unnecessary but in some cases may also damage the engine, and this kind of damage is not within the scope of warranty.
Empty containers of wasted engine oil can not be thrown away along with the home rubbish. When discarding these items, please ask the qualified waste disposal agency for treatment.
