ربنا يكرمك سيدي الفاضل انا دخلت علي موقع ويكابيديا وجبت مواصفات العربيتين
البي ام
bmw 3 series (e90) 320i (2008 - 2011) de......ion & history: The famous bmw 3 series was revised by parent company bmw in 2009, with the new model presenting a bunch of reshaped parts and upgraded elements which improve both the look and the performance of the car. The most obvious modifications concern the front bumper, headlamps, the wing mirrors and the tail lamps. In terms of features, bmw enhanced the idrive system with an upgraded browser while a couple of models saw their rear track increased by 24 mm.
compare with: Pick brand...acuraalfa romeoarielaroaston martinaudibentleybmwbristolbugattibuickcadillaccat erhamchevroletchryslercitroendaciadaewoodaihatsudm cdodgedonkervoortferrarifiatfiskerfordfsogeelygmcg ta motorhindustanholdenhondahummerhyundaiinfinitiisuz ujaguarjeepkiakoenigseggktmladalamborghinilanciala nd roverlexuslincolnlotusmarussiamaruti suzukimaseratimaybachmazdamclarenmercedes benzmercurymgminimitsubishimorgannissanoldsmobileo pelpaganipanozpeugeotpontiacporscheprotonrenaultro lls roycesaabsaleensamsungsantanasaturnscionseatskodas martspykerssangyongsubarusuzukitata motorstesla motorstoyotatvrvauxhallvolkswagenvolvowiesmannzend er
see also: other engines · photo gallery
technical specifications · features
bmw 3 series (e90) 320i (2008 - 2011) dimensions, ground clearance, fuel, acceleration
general
cylinders
inline 4
displacement
1995 cm3
power
125(170)/6700 kw(hp)/rpm
torque
155/4250 lb-ft/rpm or 210/4250 nm/rpm
fuel system
direct injection
fuel
petrol
co2 emissions
148 g/km
performance
top speed
141.7 mph or 228 km/h
acceleration 0-62 mph (0-100 kph)
8.2 s
والبيجو
technical highlights
peugeot has equipped the european-market 508 with its hdi common-rail diesel engines. The 1.6-litre hdi 112 can be fitted with the e-hdi 'micro hybrid' system, including an electronically-controlled automatic gearbox, which reduces fuel consumption to 67.2 mpg-imp (4.20 l/100 km; 56.0 mpg-us) with co2 emissions of 109 g/km.[8] though this matches the volkswagen passat bluemotion, it features a slightly larger fuel tank which allows it to cover a slightly longer range of 1017 miles.[9]
the 508 range will also include psa's hybrid4 diesel-electric hybrid powertrain, which will reduce fuel consumption further, to 74.3 mpg-imp (3.80 l/100 km; 61.9 mpg-us) with co2 emissions of 99 g/km.[10]
the top gt version comes with a 201 bhp (150 kw; 204 ps), 2.2-litre turbodiesel engine which generates 338 lb·ft (458 n·m) of torque. It comes mated solely to a six-speed torque converter automatic gearbox which offers manual shifts via paddles or a central
peugeot 508 1.6 turbo active (a)
engine
engine capacity
1,598 cc
engine type
4-cylinder 16-valve dohc twin-scroll turbocharged
compression ratio
10.5
bore x stroke
(77 x 85.8) mm
performance
power
156 bhp
torque
240 nm
acceleration
9.2s (0-100 kmh)
top speed
220 kmh
fuel consumption
14.1 km\l
misc technical data
transmission
6-speed (a) tiptronic
drive type
fwd
measurements
body type
luxury sedan
dimensions (l x w x h)
(4792 x 1853 x 1456) mm
wheelbase
2,817 mm
min turning radius
12 mm
kerb weight
1,410 kg
fuel tank capacity
72 l
brakes
brakes (front)
ventilated disc
brakes (rear)
disc
suspension
suspension (front)
macpherson independent, coil springs and anti-roll bar
suspension (rear)
multi-link arm, anti-roll bar
لاحظ التسارع من صفر ل100 والسرعة القصوي
انا اسف فعلا على الغلطة فى احصنة البى ام هى 170 فعلا مش 150 انا اتلخبطت فى حاجة تانية
بس برضه انا لسه عند رأيى ان البيجو عادى انها تسبقها
