رابط
دى سوائل تبريد لسيارات فولكس من شركه اسمها OPie
http://www.opieoils.co.uk/c-1551-vw-...ntifreeze.aspx
يتضح الاتى :
- G11 يمكن خلطه مع G12+ او G12++ فقط
- G11 لا يمكن خلطه مع g12 او g13
- G12 يمكن خلطه مع G12+ او G12++ فقط
- G13 يمكن خلطه مع G12++ فقط
- G13 لا يمكن خلطه مع G12+ او G12 او G11
VW G11 (TL 774 C) Specification Antifreeze
Looking for G11 (TL 774 C) spec antifreeze for your Volkswagen car, find our range right here
Opie Oils stocks a great range of Coolant and Antifreeze that meet specific VW specification G11 (VW TL774 C). Volkswagen models manufactured before 1997 used G11 coolant, typically (but not always!) coloured blue. G11 coolant is equivalent to the VW blue coolant part numbers G011000 and VW-W043611. G11 VW coolant should not be mixed with the later G12 coolant but *can* be mixed with the G12+ and G12++ coolant that supercedes both G11 and G12. G11 coolant is not a longlife coolant and should be replaced every 12 months. If you are unsure as to what kind of coolant you have, the safest option is to drain, flush and replace with the latest, longlife G12++ coolant.
VW G12 & G12+ (TL774 D / F) Specification Antifreeze
Looking for G12 & G12+ (TL774 D / F) spec antifreeze for your Volkswagen car, find our range right here
Opie Oils stocks a great range of Coolant and Antifreeze that meet specific VW specification G12 / G12+ (VW TL774 D / F).
Volkswagen G12 and G12+ coolants are longlife coolants; replace every 3 years. G12 cannot be mixed with the earlier G11 coolant but can be mixed with G12+ and G12++ coolants. G12+ coolant can be mixed with both G11 and G12++.
VW G12 & G12+ Antifreeze (TL 774 D / F)
VW G12++ Antifreeze (TL 774 G)
VW G12++ Antifreeze (TL 774 G) Specification Antifreeze
Looking for G12++ Antifreeze (TL 774 G) spec antifreeze for your Volkswagen car, find our range right here
Opie Oils stocks a great range of Coolant and Antifreeze that meet specific VW specification G12++ (VW TL774 G).
Volkswagen G12++ coolant is a longlife coolant; replace every 3 - 5 years. It can be mixed with everything that VW / Audi have used as a factory fill coolant, so this is a safe option if you don't know what's in your cooling system already.
VW G13 Antifreeze (TL 774 J)
VW G13 Antifreeze (TL 774 J) Specification Antifreeze
Looking for G13 Antifreeze (TL 774 J) spec antifreeze for your Volkswagen car, find our range right here
Volkswagen G13 coolant is a longlife coolant; replace every 3 - 5 years. It can be mixed with all coolants meeting the G12++ (VW TL 774 G) specification. Volkswagen G13 coolant is a more environmental friendly coolant.
